Old 03-02-2007, 08:35 PM   #1
jcfoote60
Active Member
jcfoote60's Avatar
Blazer body mount replacement
Guys, I remember a really good thread on Blazer body mount replacement and now that I am to that stage I need to find it, not sure where it went and all of my searching has not turned up what I remember. Can someone point me to it? If not how about some advice, as I remember it was recommended that the top should be on and to remember to replace the shims EXACTLY where the old mount locations had them and to do one side at a time....
It's been a long week and maybe I am just tired but I can't find that thread. Any assistance would be appreciated
Jim
jcfoote60 is offline   Reply With Quote
Old 03-02-2007, 08:37 PM   #2
1969k10stepside
Re: Blazer body mount replacement
this one?
1969k10stepside is offline   Reply With Quote
Old 03-02-2007, 09:15 PM   #3
jcfoote60
Active Member
jcfoote60's Avatar
No it was Blazer specific and talked about the fact that they are truly a convertible so care must be taken to make sure everything stayed in alignment...as I recall
Old 03-02-2007, 11:35 PM   #4
70gmcjimmy
GMCDAC
70gmcjimmy's Avatar
JCFoote, I'm gonna TTT one from last summer since I'm a duma$$ on how to attach a thread. Can do pics fine, cant do the threads----. Hopefully its the right one as I actually am at this phase too and all the stuff then was guessing. Just look for "Got Body Mounts?"
Later DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild!
1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish!
1955 GMC 100 2nd design driven almost daily!
Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09
GMC driver for 30 years!
70gmcjimmy is offline   Reply With Quote
Old 03-03-2007, 11:33 AM   #5
jcfoote60
Active Member
jcfoote60's Avatar
that's the thread!! Thanks a lot, this is what makes this forum so cool!! I have my floorpans done and have my rockers scewed in with self tappers but have not welded them yet. My doors are hung and gaps look great...now I happen to notice my mounts.....so much for adjusting the doors and now I am hesitant to weld my rockers in before changing the mounts! But the work need to be done. I am worried about the flex in my floor with the rockers not welded, do you think I should put the top on prior to trying to lift it?
Jim
Old 03-03-2007, 12:50 PM   #6
jaros44sr
jaros44sr's Avatar
Jim
I am about where you are, put more self tappers in if you are uncomfortable with strenght, I think they are as strong as spot welds. Mine are every 3/4". I've stood on my rocker panel with out any flex. I haven't done any welding yet, floorboards are all zip screwed in.
If you are running it with a hardtop then mount it up and do your body mounts, you don't have to lift it that high. J
Actually, this is the best time to do your mounts, as the rocker line to door is the only thing that can screw you up. Since you your not attached at that area you can still move it around after you get yor mounts done. jmho
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
