03-03-2007, 02:58 AM | #1 |
starter wont disengage
i have searched the forum for old threads i thought i read one a while back on this but had no luck finding it so i guess i will just ask
my starter has been missing quite abit latly so i figured i would drop it out clean it up a bit mabe fiddle with it see if i couldnt fix it before i go buy all the parts for it so i did that tried it and didnt make much difference only that it will wouldnt dis engage untill i disconnect the battery today i bought a new solenoid and brushes put it all in put the starter back in allt he same wires to the same places all that tried it and it noticably engaged stronger and turned a bit faster but wen i took the key out it didnt stop turning over till i took the battery off luckly its kinda cold and my truck sucks at winter it wont start at all if its not plugged in if it has some heat it willl fire up like nothing any way would anyone mabe know whats goin on here i have changed nothing but the the solenoid and brushes the starter was re assembled with no left over parts or anything so i dunno what to do ideas???? |
03-03-2007, 03:12 AM | #2 |
Designated A-hole!
Re: starter wont disengage
Sounds like you might need a new bendix (drive gear the starter spins). Check the clearance between the bendix gear and the fllywheel/flexplate first, you may just need to shim the starter.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" Last edited by krue; 03-03-2007 at 03:13 AM. |
03-03-2007, 03:20 AM | #3 |
alrite thanks for the response ill check it out tommorow
