Old 03-03-2007, 05:24 PM   #1
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Dana 70 4X4 Axle Set..............
Anybody need These Honker's.................
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
toomanytoyz is offline   Reply With Quote
Old 03-03-2007, 05:33 PM   #2
1969k10stepside
Re: Dana 70 4X4 Axle Set..............
So,after hearing the negatives on the dana 60 rear,and the positives on the dana 60 front,how does the dana 70s compare,anyone?
1969k10stepside is offline   Reply With Quote
Old 03-03-2007, 05:56 PM   #3
b454rat
That front is junk. It's closed knuckle drum brake. A 60 front is stronger than that. Even if it was the open knuckle, disc brake, it isn't really THAT much stronger than a 60. It will have a bigger ring gear and the 35 spline outers. There is one of the axles in a yard here, and that is the reason it still sits there, or I would have got it by now.....The rear tho is fine, looks like it has a Powrlok...
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 03-03-2007, 09:23 PM   #4
Southedisto
River life......
Southedisto's Avatar
X2, 70 sounds nice, but they are crappola.
Southedisto is offline   Reply With Quote
Old 03-03-2007, 09:26 PM   #5
1969k10stepside
So bigger isnt always better....lol
Old 03-03-2007, 09:58 PM   #6
The Dana60/70 combo came in the M41s.They`re tougher than what`s under most every 4wd.Just not the best.The Dana70 is one tough rear end that`s hard to beat.
Old 03-04-2007, 05:40 PM   #7
stan79chevy
stan79chevy's Avatar
b454rat is correct. dana 70 front is going to be heavier...drum brakes just suck...locker options are limited..gear options are limited...prices for replacement parts are going to be rediculous. you could get 60 hubs and stuff and swap it to a disk brake set up but then youve just got an expensive cobbled dana 60. dana 70 rears can be broken...i busted the pinion yoke clean off and shot pieces of the locker through the cover.
stan
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
Old 03-04-2007, 07:10 PM   #8
1969 GMC
1969 GMC's Avatar
stan
While I agree with part of what you are saying, there are plenty of locker and gearing selections for Dana 70's. Anywhere from 3.07's up to 7.17. If you need more (or less) gearing than that, you need another type of axle (and perhaps some mental help ) Detroit locker, lock-right, power lock posi, arb air locker, and im sure there are more.
If you think some brake parts are tough to find for Chevy's, those front brakes will be just as much of a nightmare, not to mention if you have to replace kingpins or any other parts.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 03-04-2007, 10:49 PM   #9
1tonswb
1tonswb's Avatar
If you had a 60 front with a bent housing or if your eating front ring and pinions then it would be nice to have the 70 front to weld your 60 inner c's on. After all, the front 70 does look like its got a detroit in it.
1tonswb is offline   Reply With Quote
Old 03-04-2007, 10:56 PM   #10
1969 GMC
1969 GMC's Avatar
Good eyes, I didn't bother to check cuz the pic was so dark. With it lightened up, sure does look like one to me.
1969 GMC K2500
1996 Honda Accord
Old 03-05-2007, 01:48 PM   #11
toomanytoyz
Luv the Crewcabs
Same Seller Just got over $1000.00 for a Set Of 60's, Make's me feel Real Good on Getting The Deal i Got on My 60's For The Wrecker Project.........
Old 03-06-2007, 12:36 AM   #12
Blue_71
Bloo
Blue_71's Avatar
isnt the 14 bolt pretty much the same as a dana 70 rear, except the 14 bolt has a larger pinion shaft/bearing?
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 03-06-2007, 11:05 AM   #13
Welllll....I wouldn`t say that.You know they aren`t even made by the same companies and the design surely varies.
Old 03-06-2007, 11:09 AM   #14
toomanytoyz
Luv the Crewcabs
Just checked the Auction & seen Someone Dropped out of Bidding, Maybe someone Read This Thread, It's Down to $ 405.00 Now...........
Old 03-06-2007, 08:23 PM   #15
Blue_71
Bloo
Blue_71's Avatar
special- yup, ones a GM and ones Dana, i guess i should have worded that better
i read somewhere one time that strength for strength, and most of the specs (axle tube dimensions, axle shaft diminsions, stock brake sizes, that kinda thing) are pretty well equal between the 2, but the 14 bolt 10.5 FF had a bigger pinion. i think it may have been peterson's 4 wheel and off road maybe?
Old 03-06-2007, 08:43 PM   #16
DieselEater
DieselEater's Avatar
Well.....Here in the pullin' world, I've heard many Ford guys admit that the 14-bolt was tougher than the D70. I've also heard, like in previous posts you've probably seen that the H 072 is just as tough or tougher than the 14-bolt. We have guys in our Pullin' association pushing 800+ HP through 14-bolts every weekend at 7500+RPM and they live all day long!!!!!!! The D60 is not even considered for pullin' at this level....
GET A 14-BOLT...THEY'RE DIRT CHEAP, AND STRONG!!!!
D60 front....the aftermarket has made them VERY STOUT...
DieselEater is offline   Reply With Quote
Old 03-07-2007, 03:31 AM   #17
1969 GMC
1969 GMC's Avatar
The real difference is the 14 bolt's 3rd pinion bearing. The D70 only has 2, further apart. The Eaton also has 3. It makes it harder for the pinion gear to "walk" away from the ring gear under load.
Oh, and read Petersen's 4WOR with a grain of salt. They print up a LOT of mistakes.
1969 GMC K2500
1996 Honda Accord
Old 03-07-2007, 07:19 AM   #18
Yeah,I read recently that the 400SBC came in 2wd trucks since 1970,for instance.
Old 03-07-2007, 08:05 PM   #19
Blue_71
Bloo
Blue_71's Avatar
so does the LD 14bolt SF 6 lug have 3 pinion bearings too?
on the "walking away from the ring gear" thing, i bet thats what happened to the D70 4:10 locker i have in the field with no ring gear teeth left is that even worth rebuilding?
you both have a very good point about the reading with a grain of salt
Old 03-08-2007, 12:21 AM   #20
I can`t say on the semi-floater(8 or 6 lug).I`ve never been into one myself.I have one in a`91 3/4t Suburban,though.
Old 03-16-2007, 12:49 AM   #21
snj8198
snj8198's Avatar
Hi Blue, the SF14 is a standard c-clip axle without the removable pinion support on the front.
snj8198 is offline   Reply With Quote
