Old 03-04-2007, 11:56 AM   #1
74 shortbed 406
Installing lockouts
I just installed lockouts on my truck last week and am questioning somethingh that has been bothering me. I removed the auto hubs that were in it and the only clip that was holding it in was the one holding it to the hub on the outside. There was not anything on the axle. Well I installed warn lockouts in it and I removed everything inside hub except the hub nuts and the hub would slide in only far enough to get the outside ring clip in and would need another 1/4 in to get the circlip for the axle in it. If I were to get the lockout assembly into the hub that far I will have to remove the locking nut inside the hub. I know these hubs come with extra stuff for a multitude of of applications but I was wondering if this was right. The instructions called for the removal of spacers and washers but no nuts. I forgot to mention; 87 k10 with a 10 bolt front.
74 shortbed 406 is offline   Reply With Quote
Old 03-04-2007, 12:15 PM   #2
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Re: Installing lockouts
You need to pry the outer stub shaft outward by sticking a big screwdriver or small prybar behind the U joint yoke. there is a rubber "boot" lip seal that is applying pressure, pulling the stub shaft in. Then the shaft snap ring will go in- it needs to be installed.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
