03-06-2007, 12:12 AM | #1 |
Shock Question(s)?
If you bought the same type of shock from the same manufacturer (1 front & 1 rear shock), how different do you suppose the shocks are as far as valving & stiffness?
I'm curious because for the rear of my 74 I used what fit the location given the compressed, extended, & ride height requirements. The shock that fit was actually for a 73-87 Chev 4wd front. I haven't really noticed an "oh sh**, that rides like crap" sensation & they were easy enough (& cheap enough) that it was worth trying..... so they've worked fine. I'm trying to get my 68 sorted & wanted to get a better quality shock (Bilsteins). My dilemma is they don't make a rear shock for 67-72 trucks & later years seem to have wayyyyyy wrong dimensions to be able to retrofit. I can however adapt a few different shocks that are again intended for the front of a vehicle. Please.... I'm not interested in the 'drop shocks' that several companies offer. I prefer to make my own brackets & use the correct (or close to it) shocks. Think the valving is that different (or does anyone have some technical input?). Let me know your thoughts on the subject.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-06-2007 at 12:14 AM. |
03-06-2007, 04:44 PM | #2 |
Re: Shock Question(s)?
Have you considered an adjustable shock? Then you can dial it in to your personal preference.
'67 C10 Short Stepside 5.0TPI/700R4 |
03-06-2007, 05:26 PM | #3 |
My shocks looked and felt the same before I installed them. The valving should be the same as well. Most of my shock experience is with off road shocks and all of them are valved the same unless you have them valved different.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
03-06-2007, 11:18 PM | #4 |
If you can get a Bilstein shock to fit and find that you don't like the feel, you can have it revalved.
'67 C10 Short Stepside 5.0TPI/700R4 Last edited by CochinoFilipino; 03-06-2007 at 11:18 PM. |
03-06-2007, 11:56 PM | #5 | |
I just wanted to keep the valving close for the front/rear of the truck. Since they had a 'lowered' application for the later model (chevy truck @ that)..... I figured I would give it a shot.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-06-2007 at 11:57 PM. |
03-07-2007, 12:32 AM | #6 |
Hey SCOTI, do you have any dimensions on those rear shocks, like compressed and extended height? What type of mounts do they use top and bottom?
03-07-2007, 01:01 AM | #7 | |
I measured a buddys truck in the parking lot @ work today. It's stock (stock height) & the shock length @ ride height was 18". They use a 9/16" x 1 5/8" bolt on bottom & a 'T' bracket on top (I'll just pull the 'T' out of the top shock eye & stick a bolt through). The rear shocks I ordered are for trucks w/a 6" drop so I figure (ok, I'm hoping) they're shorter than stock.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-07-2007 at 01:03 AM. |
03-07-2007, 01:34 PM | #8 |
SCOTI,
Keep us posted on how all this turns out with the Bilsteins. I have had good experiences with them on other vehicles and would like them on my lowered 68. Where did you order them from and how much $? Brett |
03-07-2007, 04:11 PM | #9 | |
I ordered them from Summit @ approx $65ea.
03-08-2007, 01:37 AM | #10 |
OK, I will be watching for the results.
03-13-2007, 01:35 AM | #11 |
Ok.... update time.
As always, nothing comes easy in my world. The front shocks are the exact dimensions they're supposed to be, but . . .... they have the upper stud permanently attached . So I had to cut off the studs on some brand new shocks only to realize I now had to sleeve the rubber bushings. I had a couple of old front shocks lying around & pressed out the sleeves. One of the sleeves fit perfect..... the other is much too loose. It seems the bushing I.D. is larger on one of the Bilsteins than the other. Luckily I have a 'spacer' that came w/some brackets on another project. I'll have to use it after turning it down to the correct O.D. & drilling it for a 1/2" bolt. Then I can mount the fronts. The rears are going to take some creativity. . ..... more than I hoped. I was guessing that because the spec'd application was a 88-98 C1500 w/a 4/6 drop, the shocks would be shorter than stock..... they aren't (I don't understand why they list one P/N for a C1500 & another for a 4/6 lowered C1500 ). Extended length is 22" & fully compressed is 14". My truck @ ride height requires 14" shocks. So somehow I have to create 4 more inches of travel. I'll prob relocate the top mount (more than it already is) & lower the bottom mount 1 more inch while trying to position it so it's not any further below the 'scrub' line. I'll post up picks after I come up w/something decent.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-13-2007 at 10:46 AM. |
04-02-2007, 12:25 AM | #12 |
I tried a couple of different combos to mount the rear 88-98 shocks in the factory 68 rear shock mount orientation.
The first attempt was to put some studs for the 'T' brackets & open up an access hole for the top of the shock (similar to what is used on 88-98 models) in the 68's shock c.member using the 68's shock geometry. I felt the shocks angle was too compromised to work correctly. My second attempt was to run the shocks straight down to a fabricated bracket that would be held in place by the trailing arm u-bolts. After mocking the shocks into place (this required relocated new top studs & another access hole ) , I decided that the lower mount would be way too low. So..... I cut the stock shock c.member & raised it 3". This will allow using the factory upper shock brackets & shock geometry. I'll make a new lower mount that drops the stud 1" & this will get me the 18" shock length required @ ride height. Not exactly a bolt-in swap but it should work decent enough. I was going to have to modify the bed floor to clear the rear end pumpkin anyway. This will also allow for more room to run exhaust pipes over the rear end. I also learned that the front Bilsteins are 1.5" longer than the Monroes I used when fabricating my front shock relocation brackets which means I would have to live w/less than 2" of front shock compression. I'll either have to swap the brackets or re-fab the current ones & raise the shock mount holes 1" higher.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-02-2007 at 12:26 AM. |
04-03-2007, 12:02 AM | #13 |
Too bad they don't just make a shock closer to what we need. After you are done with all the fab. it will probably be worth it though. I switched from KYB gas-adjust to Bilsteins on my Camaro and there is a major difference in ride quality. The KYB's were way too harsh.
