Old 03-06-2007, 02:57 PM   #1
CochinoFilipino
CochinoFilipino's Avatar
Manual valves
I'm going to put bags at all four corners. I want to keep it simple as possible. I might not even use a tank. But I still want to be able to control the rear from inside the cab.
The rear will be adjustable to handle loads. And also be independent side to side to counter roll. The front will be static.
I see two types of manual valves from MIC. One is a 2-port valve, that I'm guessing is either open or closed.
The other manual valve is a 3-port 2 position valve. But I don't know what the 2 positions are. Anyone know? I called and and got a busy signal. The picture shows the toggle in the middle, i wonder if it's actually a 3 postion valve.
'67 C10 Short Stepside 5.0TPI/700R4
CochinoFilipino is offline   Reply With Quote
Old 03-06-2007, 03:37 PM   #2
CochinoFilipino
Re: Manual valves
This is the type of valve I was looking for, 3 way 3 position. Two of these and I should be good.
http://www.coolcars.org/air/Detailed/40-SW33.htm
Old 03-06-2007, 06:01 PM   #3
PBFAB.COM
PBFAB.COM's Avatar
Re: Manual valves
I've used the MIC valves in the past with good results. I don't remember the part# but the least expensive one (it has a cylindrical look) works great, and should be exactly what you want. The other one (that looks like a billet block with MIC machined into it) works well also... just a little fancier and a larger orfice.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 03-06-2007, 09:53 PM   #4
leftcoast66
leftcoast66's Avatar
Re: Manual valves
I've had great results w/ mine, 4 years and no issues... I heard though that the quality went down the drain a year or so ago or whenever it was bought out and all the good workers and such left. People have had issues w/ the new valves I've heard.
leftcoast66 is offline   Reply With Quote
Old 03-06-2007, 11:06 PM   #5
randomhero472
randomhero472's Avatar
Re: Manual valves
i used them on a car about 5 years ago.. never had any issues
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
Old 03-06-2007, 11:12 PM   #6
CochinoFilipino
Re: Manual valves
So the MIC 3 port valves are really 3 position valves? Their site says "2 position".
http://www.masterimagecustoms.com/store/manualav.html
I'm looking to use just one (3 port 3 position) valve for each bag (up,down,closed)
I sent an email but haven't got a reply yet.
Thanks,
Old 03-06-2007, 11:39 PM   #7
PBFAB.COM
PBFAB.COM's Avatar
Re: Manual valves
I looking to use just one (3 port 3 position) valve for each bag (up,down,closed)
Thanks,
The valve pictured is one I have used before... It is a needle and seat style valve (closed, air in, and air out). There are o-rings inside that will eventually wear, but they also sell a rebuild kit. It has three ports and can be a little tricky to plumb... for some reason I remember it took me way too long to figure out which port was which. It made me feel really stupid.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 03-07-2007, 01:43 AM   #8
CochinoFilipino
Re: Manual valves
Cool, Thanks
