03-06-2007, 07:12 PM | #1 |
3 on the tree linkaging pictures
anyone have any pictures of their linkages i just got a set and now i need to hook them up and i cant seam to figure out which ones go where and over or under the clutch linkaging any pictures or advice would help a lot would like to have it working soon so i can get a handle on three on the tree before i drive to far
1971 c10 350ci long bed fleet side |
03-06-2007, 08:32 PM | #2 |
Re: 3 on the tree linkaging pictures
pictures from the topside would really help im really confused on about how these linkages run or where to buy parts like the bushings
03-07-2007, 03:04 AM | #3 |
yeeha
ttt for you because I need to know too That would be one thing I never did get a picture of before it came apart
1969 GMC 910 97% rust free 2002 olds Alero 1986 New Yorker 4dr ... the new DD...My POS car... dude its got a turbo!!! Don't drink and drive, you might spill something!!! Daryl Kuchmak |
03-07-2007, 11:25 AM | #4 |
There is a post in the FAQ sticky about adjusting the 3 speed manual. Maybe it will help.
http://67-72chevytrucks.com/vboard/s...d.php?t=215307 Or PM the author?
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
03-07-2007, 09:20 PM | #5 |
yeah i already looked there no pictures of it i seam to be runnign into clearance issues with clutch linkaging
03-07-2007, 09:53 PM | #6 |
Resident Curmudgeon
Not sure if this helps, best I could do. This is a STOCK 69-72 small block/3speed column linkage set up. There ARE differences between 67/68 trannys and I6 setups (all years). It may also make a difference if you put your small block in the forward (factory correct) position, or in the rearward I6 position
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
03-07-2007, 11:36 PM | #7 |
thanks that makes all the difference i was putting the rods in upside down no wonder they didn't want to line up thanks a lot now i think once i dint the pieces to connect them to the column and tranny i can get it to work
