The Blazer King
Please give the proper wheel off set for some 16x8's front & 16x10 rear.
5 lug 2wd. ------------------ 71 2wd Blazer. Its the super*****inest, megacoolinest, superflowinest. 350/350 Turbo. 750 Holley Double Pumper, Edelbrock RPM performer intake, big cam,Headers,Dual Flowmaster, and convertible all the time.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
The Blazer King
To the Top. Please let me know. Please e-mail me if you can.
4.5" backspacing on the front and back. I went with 5" in the back to tuck it in a bit more.
------------------ 68 SWB The Surgeon General doesn't say anything about smoking a Ford!!! Would rather be ran over repeatedly by a Chevy than drive a Ford!!! Paralyzed from the neck up and confined to a hat!
68 SWB The Surgeon General doesn't say anything about smoking a Ford!!! Would rather be ran over repeatedly by a Chevy than drive a Ford!!! Paralyzed from the neck up and confined to a hat! Kathleen, Georgia USA |
Is it lowered?? That can make a diff when measuring for b.space.
The Blazer King
It is not Lowered, but will eventually have a 3/5 drop. Also, what is the Lug pattern?
The Blazer King
Lug pattern anyone? I have no clue on this.
As far as i know it should be a 5 on 5 lug pattern. I am not sure about the back spacing problem i am going thru the same thing right now my self. Good luck and let me what you find out.
------------------ 1968 swb IM-Bufechevy56
1968 swb IM-Bufechevy56 If its to loud then your to old |
Got 20's????
Don't go any more than 5.5 backspace or else your tires will rub unless you do a mini-tub. 4" offset all around looks good, but 5" offset in the back would be even with the rear wheel well. If you plan on tuckin' the wheels you will need 3" offset.
------------------ 72 Chevy C/10 87 Chevy Silverado 4X4 www.geocities.com/chevylwb/chevylwb.html Aberdeen South Dakota WANTED: Drop Spindles F/S: rebuilt Turbo 400 & Aluminum wheels w/ tires
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged 02 Sierra Ex-Cab 4wd 2500 HD The 72 went down the road. |
