Old 03-08-2007, 10:57 PM   #1
DangerBoy
Edelbrock carb question
I'm running an Edelbrock 1406 with an electric choke that isnt hooked up. Is it possible to hook up the choke to work manually instead of electric?
2002 S10 ZR2 for the dirt.
1968 C10 shorty for the street.
She said the truck would be the end of us. I still have the truck!
DangerBoy is offline   Reply With Quote
Old 03-08-2007, 10:58 PM   #2
QKENUF4U
QKENUF4U's Avatar
Re: Edelbrock carb question
not from what ive read. you have to either have the electric one or you get the manual one cant have both from one carb. i took mine off all together lol
QKENUF4U is offline   Reply With Quote
Old 03-09-2007, 01:06 AM   #3
67chevemall
67chevemall's Avatar
look into the Manual set up for the 1400 ser. Ed. carbs.
probly just unbolt the electric and bolt up the manual set up
The OEM choke cable is short so plan on getting a aftermarket.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 03-09-2007, 09:37 PM   #4
mnunn454
mnunn454's Avatar
For $22, Here's a divorced (no cable) choke kit. It adapts to a Performer manifold and carb.
http://store.summitracing.com/partde...5&autoview=sku
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 03-09-2007, 10:04 PM   #5
bad72c10
bad72c10's Avatar
Alright, here's the deal, you know how to adjust the choke, right? Loosen the three screws around that plastic housing, and turn the black case to adjust the cold position of your choke. When your truck is cold, loosen those 3 screws, and turn that housing until the spring engages to the point that the choke is ALL the way open, tighten screws. Game over, put your wire to it and give it power, and ground the other side, and it won't open any more than that, because you have it all the way open when it's cold, so it won't open when its hot. That'll save you some cash too. Justin
'72 C/10 SWB 355/ broken TH350 and 3.07s Soon to be 355/700r4 and 3.73s
bad72c10 is offline   Reply With Quote
Old 03-09-2007, 10:06 PM   #6
FLEET72
FLEET72's Avatar
Actually it allows you to use a Q-Jet divorced choke carb on a Performer Manifold.
Yes it is possible, why do you not want to use the electric choke?
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 03-09-2007, 10:08 PM   #7
bad72c10
bad72c10's Avatar
Ha, oops, I guess you still want a choke,huh? Well, I guess mine won't work if you want an actual choke, but if you live where it's warm, you don't need one anyway. Justin
