Junior Member
![]() Join Date: Dec 2003
83 Tilt column for sale
Bought and realized it was different from my 87. The person I bought it from said it was solid and appears to be. 90.00 shipped
DINGER! ![]() Last edited by Brian Ringer; 03-10-2007 at 06:35 AM. Reason: Wrong year of make. |
Re: 85 Tilt column for sale
How is it different that your '87?
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
![]() Join Date: Jun 2004
manual trans or auto trans column, tilt?
John
Locab36 1936 low cab 1/2 ton ![]() 1956 BMW R25/3 1968 Moto Guzzi V7 1969 BMW R100/2 1986 Silverado SWB ![]() 2007 Harley FLHTP 2011 GMC SWB 4x4 Z71 ![]() http://www.flickr.com/photos/locab36...7623329816080/ |
Junior Member
It is for a auto trans it it is a tilt column. When I bought it I was told it is solid. I couldn't use it due to I have an 87.
DINGER! ![]() |
Junior Member
The 85 bright switch is on the floor 87 is on the column. And the wiring appeared to be a little different. I just wanted something to bolt right in and with the 85 I would had to do some re-wiring.
DINGER! ![]() |
If the column is for a floor mounted dimmer it is 83 and older. GM put the dimmer on the column in 84.
Does the column have the wiper control switch on it? If not, like was said before it is for '83 and older (or is it '84?).
Junior Member
It must be 83 or older because that was the other thing I was trying to remember what was different from my 87. I was told it was from an 85. I just got the suburban a few months ago and don't know all the details about them. Thanks for the info.
DINGER! ![]() |
