Old 03-11-2007, 05:36 PM   #26
Hart_Rod
Hart_Rod's Avatar
Re: Project '70 Half Fleet
Gotta love progress pics! Where'd you get that rearend at? You've been holding out...........!!
Hart_Rod is offline   Reply With Quote
Old 03-11-2007, 06:20 PM   #27
BowTieOgre
Originally Posted by Spray-Bomb View Post
On your gauge panel, you could put a pic a your kid or somethin in that middle hole
Just a thought
Yeah when I came to the conclusion that a 3-3/8" Autometer gauge was probably not in my future I started thinking about what to do with hole. A pic of the fam was definately on the list but I also thought about turning it into a small storage compartment for stogies, radio remote, etc. OR installing a nautical style compass. Jury is still out on that.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 04-20-2007, 10:52 PM   #28
BowTieOgre
After I installed the rear disc setup (thanks to Glock35ipsc) I took the motor/trans back out to run the brake and fuel lines. Now that the lines and tank are mounted i can reinstall the motor/trans and begin to route the exhaust. That should happen this weekend, after that I can begin work on the cab and hopefully get my harness and PCM back in the next month so I can fire this baby up!
No making fun of my makeshift engine cradle!
Old 04-22-2007, 01:06 PM   #29
Hart_Rod
Hart_Rod's Avatar
Looks like your almost ready for an alternator, . When you going to come see me? 68 POS from FT Walton is coming up this afternoon at 4 to pick up some parts. I'm heading to Montgomery next Sat morning to grab the other part of the frame I need for DONKEY. Todd's going and maybe another buddy.....sounds like a good road trip.
Old 04-24-2007, 09:51 AM   #30
BowTieOgre
Yeah im about ready for that alternator. I dropped the engine back in and bolted up the poly mount for the trans so now im on to the exhaust...which is a PITA. The headers are SUPER close to the engine towers and I just found out that there are at least 2 header bolts snapped off in the block...yay!
Old 04-24-2007, 10:37 AM   #31
Hart_Rod
Hart_Rod's Avatar
Sound lik it's time for an easy out! If you need any help let me know. Do you need anything from Montgomery? Looks like I'm headed up there Sat morning.
Old 04-24-2007, 11:02 AM   #32
Yukon Jack
Yukon Jack's Avatar
That is a great project - good to see everything you have done so far.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-24-2007, 06:48 PM   #33
itsmike2k
Is the rear disk setup from an Impala or ?? I have a 72 with a 96 lt1 that i'm tearing back down to the frame..
itsmike2k is offline   Reply With Quote
Old 04-24-2007, 09:36 PM   #34
BowTieOgre
The rear calipers came off the same '96 Caprice that I got the engine/trans from. I bought some brackets from a board member that mounted the calipers on the 12 bolt axle flanges. He included a parts list (that I promptly lost) that indicated which pads, rotors, etc to get to finish the install.
What did you use to plug up the intake elbow hole and how did you solve your A/C compressor clearance issue?
Old 04-24-2007, 11:17 PM   #35
itsmike2k
The plug is a horn button off one of those old steering wheels and the ac i cut the frame. I think it was about a 1" or so in by the length of the ac compressor.
What headers are you going to run? I'm wondering if Impala or camaro shortys will work good? I'm going to get the 1le elbow to eliminate the plug but i havent decided what type of air intake i'm going to run..
Later
Mike
Old 04-24-2007, 11:24 PM   #36
franky69c10
chevy runs deep
franky69c10's Avatar
nice.............
franky69c10 is offline   Reply With Quote
Old 04-24-2007, 11:41 PM   #37
BowTieOgre
Later
Mike
Any chance I could get a pic?
Thanks Franky...it does me good to hear positive comments every so often.
Old 04-24-2007, 11:52 PM   #38
itsmike2k
of the frame? i can get one tomorrow..
Old 04-26-2007, 01:26 AM   #39
itsmike2k
Here's the pictures of the frame
Old 04-26-2007, 01:27 AM   #40
itsmike2k
I plan on boxing the frame there when i pull the engine
