Old 03-12-2007, 07:52 PM   #1
creeldaddy
creeldaddy's Avatar
frame paint
what is the best paint to use on the frame
my dad had some black epoxy paint left over from something so i used it this is what it looked like when finished
it has been drying for a day and still seems wet any idea how long for it to dry?
creeldaddy is offline   Reply With Quote
Old 03-12-2007, 08:11 PM   #2
Fastfun
Fastfun's Avatar
Re: frame paint
Did you follow the directions and add the hardener????
Fastfun is offline   Reply With Quote
Old 03-12-2007, 08:25 PM   #3
creeldaddy
creeldaddy's Avatar
Re: frame paint
yes it says an equal amount of hardener as paint and i used 6 cups of each
Old 03-12-2007, 09:17 PM   #4
Fastfun
Fastfun's Avatar
Re: frame paint
Epoxy paint with hardener should be dry to the touch in about an hour at about 70 degree's.
Old 03-12-2007, 09:42 PM   #5
Ram-Man
Ram-Man's Avatar
Re: frame paint
Left over is the key. Hardener and paint has a shelf life. It should have been dry to the touch in an hour even if you put it on with a garden hose.
Ram-Man is offline   Reply With Quote
Old 03-13-2007, 07:18 AM   #6
CUSTOM/10
CUSTOM/10's Avatar
Re: frame paint
I agree with the guys above me "IF" it's an automotive paint, but if it's an industrial epoxy like rustoleum high solids mastic epoxy it will take longer even when new. I did two frames within the last 6 months with rustoleum and in a heated garage it took about 48 hrs @ 70 to dry. Also epoxy is temp. sensitive, if you don't keep it above 60 until it cures it may never harden correctly.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 03-13-2007, 03:00 PM   #7
creeldaddy
creeldaddy's Avatar
Re: frame paint
okay i checked it again today and it is alot harder thanks guys i guess it was because it was not automotive paint
Old 03-13-2007, 05:42 PM   #8
BCOWANWHEELS
Re: frame paint
Time To Get The Space Heater Going Asap
BCOWANWHEELS is offline   Reply With Quote
