Old 03-14-2007, 01:09 AM   #1
boostat4500
How can I stop better?
What can I do to get this thing to stop better? Eventually I'll do rear disc brakes but don't have the money right now. Are there any brakes off a newer truck that will bolt up easy by chance, something with a bigger caliper perhaps? I haven't had much luck finding upgrade brake parts so far. Thanks in advance for any suggestions.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc.
boostat4500 is offline   Reply With Quote
Old 03-14-2007, 01:52 AM   #2
Frizzle Fry
Frizzle Fry's Avatar
Re: How can I stop better?
The 71-72 front discs on my 69 work very well. It's actually shocking how fast this big ol' rig can scrub speed. It's not an Indy car but it stop as well as my 2001 Tahoe (minus ABS). Are you sure everything is working properly?
I see that you have a lift with big tires so that may be the difference. I just saw and "upgraded" front disc kit in one of my catalogs. I think it was about $200 for calipers and rotors, but I'm not sure how much better they perform.
Frizzle Fry is offline   Reply With Quote
Old 03-14-2007, 03:14 AM   #3
JimKshortstep4x4
We put the 3/4 ton booster/master cylinder on my son's Burb. We have used it on trucks and it is a good upgrade. (The Burb is not on the road yet, but soon will be).
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-14-2007, 09:48 AM   #4
boostat4500
I'd heard about the 3/4 ton booster, but when I look up part numbers, it looks like the burbs come with them stock. Is that true? What catalog did you see that kit in? Thanks.
Old 03-14-2007, 12:30 PM   #5
Frizzle Fry
After I posted my first reply I was thinking about the 3/4 ton stuff. They have bigger rotors and calipers too don't they?
Old 03-14-2007, 12:39 PM   #6
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Yes, the rotor and calipers for a 3/4 ton are different, too include the spindles and probably the tie rods too. I do know about the spindles since I have changed my 3/4tn to a 1/2 ton suspension. There is a difference between the boosters too.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 03-14-2007, 02:53 PM   #7
bagged91
Out draggin'
bagged91's Avatar
The 1/2 tons have a "single diaphram" booster, the 3/4 has the "dual diaphram" booster. Not sure if there are any differences on the rotors/calipers from a 4 x 4....
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 03-14-2007, 07:30 PM   #8
earl87gta
earl87gta's Avatar
you have a 4x4 so the easy and cheap thing to do would be get an axle out of a 3/4 ton axles you should be able to get a set for 150 to 300. Then get the 3/4 ton booster and master $80 by them sepritly not together dont know why but autozone orillys all of them charge you 50 more for the pair togther you will have around 400 in the hole swap but you will stop a lot better.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 03-15-2007, 11:53 AM   #9
Frizzle Fry
Then you're going to 8-lug right? That means new wheels too if so.
You can do a rear disc install for ~$200-$300 depending on what you buy new/used. There's a good thread on Impala SS rear discs in the truck forum if you want to go that route.
Old 03-15-2007, 04:19 PM   #10
boostat4500
Thanks for all the sugestions. I think I'll definetley try the 3/4 ton booster first. 2-300 for rear discs is feasble. I'll have to look a little more into that, have a link by chance? I'll look into doing the 3/4 ton axles too, I have to swap in a Ford front end anyway to get 4 wheel drive back so I'll see what I can find.
Old 03-15-2007, 04:29 PM   #11
SB406
FORD is a 4 letter word.
SB406's Avatar
Hit the pedal harder.
Seriously though, I'm a fan of the 3/4 ton booster. Works nice.
'71 406 GMC Short Box Fleetside - Daily Driver
'79 350 Chevy K-5 Blazer - On-going Project (Mudder)www.wnyoffroad.com
'58 LT1 Chevy Short Box Step Side - Next Project
SB406 is offline   Reply With Quote
Old 03-15-2007, 06:47 PM   #12
Frizzle Fry
Rear Disc Link
Old 03-16-2007, 07:38 PM   #13
earl87gta
earl87gta's Avatar
I got my rear disk brakets for 45 and calipers for 100. with new break lines every thing less then 200 in to it. But that was with out emergency break its going to cost alittle more the eldarodo calipers are expencive.
Earl
Old 03-16-2007, 09:03 PM   #14
Dadsredwagon
Dadsredwagon's Avatar
booster first.... I have a Jeep cherokee that i went from a single diaprham booster to a dual booster One of the better mods I did. good luck!
Dadsredwagon is offline   Reply With Quote
Old 03-17-2007, 09:01 AM   #15
centsless
sufficiently talented fool
centsless's Avatar
3/4 ton power brake setup
I have one for sale here....
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 03-17-2007, 10:19 AM   #16
earl87gta
earl87gta's Avatar
I bought my new 3/4 master and booster from auto zone for $80. But if you dont have power brakes already you will have to get a used set for the mounting hardware.
Earl
Old 03-17-2007, 02:57 PM   #17
boostat4500
Thanks for the link! Looks pretty simple. I think I'll step it up a notch ( over the impala ) and try to do 4th gen f-body calipers since this things heavier than a pickup. Not sure about what rotors yet ( being 6 lug instead of 5) though.
earl87gta- I assume you are 6 lug also, what did you get the rotors from? Could I just use a set of front rotors? Also, I do have power brakes all ready.
Old 03-20-2007, 09:31 AM   #18
seth 69 sub
i got a kit from classic performance products my 69 sub stops on a dime check out pics on lets see some subs page 11 or pm me here
seth 69 sub is offline   Reply With Quote
Old 03-21-2007, 02:09 PM   #19
Frizzle Fry
Just found this in FAQ (start at post 13) Turns out I have a 3/4 ton booster! That explains things
