Closed Thread
Old 03-15-2007, 06:07 PM   #251
cojnit
Nothing clever
cojnit's Avatar
Re: Let's see some Burbans!
oops forgot pics
Got "the Midas Touch!"
cojnit is offline
Old 03-15-2007, 06:21 PM   #252
Frizzle Fry
Frizzle Fry's Avatar
Originally Posted by fern's 72 GMC View Post
This is my wife's 4x4 72 suburban. Fully restoured from ground up. She thinking of selling it: I thought I share the beast with all of you!
That thing is BAAAAAD
Frizzle Fry is offline
Old 03-15-2007, 06:22 PM   #253
Frizzle Fry
Originally Posted by cojnit View Post
oops forgot pics
cojnit, I've been wondering what your Burb looked like based on your avatar pic. Very nice! Love those wheels and side exhaust.
Old 03-16-2007, 01:17 AM   #254
fern's 72 GMC
I found some more pics to share with all of you! Thanks for all of your comments!
fern's 72 GMC is offline
Old 03-21-2007, 12:39 PM   #255
cojnit
Nothing clever
cojnit's Avatar
thanks frizzle, I think I am going to bag it this spring, and then start the body and paint. Unfotunately the avatar pich happened while I was broke on the side of the freeway!
cojnit is offline
Old 03-22-2007, 09:35 PM   #256
harmsy
These things are sooo sweet.......just wish I could find one around Iowa....
They all look GREAT !!!!!!!!!
God bless the USA
1972 Chevrolet Cheyene Super ......
harmsy is offline
Old 03-24-2007, 02:54 AM   #257
bad_turbo
turbo enthusiast
bad_turbo's Avatar
these burbs are awesome!!!
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline
Old 03-25-2007, 12:56 AM   #258
sameyrasmea72
sameyrasmea72's Avatar
I just unloaded this one today.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline
Old 04-02-2007, 11:10 PM   #259
1972suburban
Here is my 1972 burban im trying to old school it but dont know what it would look like i thinking 5" white walls, lowered and flat black with pin striping.
1972suburban is offline
Old 04-02-2007, 11:26 PM   #260
bad_turbo
turbo enthusiast
bad_turbo's Avatar
these burbs sure look good
Old 04-03-2007, 01:43 PM   #261
72steel
72steel's Avatar
1972suburban---what do you think of the raised letter tires? Ours look almost identical. I will be painting mine glossy black.
72steel is offline
Old 04-10-2007, 02:39 PM   #262
quadiak
quadiak's Avatar
Here is my project, just started the other day, I got the 70' burb last summer and couldn't decide what to do with it, it's pretty rough all lower panels are completely rusted out, the frame was bent, and beat up quite bad. it had been sitting for ten years in a grassy field, I traded another truck which I basically got for free, so the burb doesn't owe me anything so far. I pulled the body off the frame and rolled a frame from a 86' 1/2 ton 4x4 under. the pic shows basically how it is going to sit on the body after my mounting mods are complete. it is a bit high but the pic looks even more so because of the tiny 215/75/r16 tires, most of the weight is still on the hoist also has no engine/trans/transfercase yet, so it will drop a fair bit i think, going to get another 6 inch suspension lift down the road anyway.
quadiak is offline
Old 04-10-2007, 03:10 PM   #263
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Did u alter the wheel base in any way, Im in process of doing same switch to my 68 & i moved the rear axle forward 4 " to mate up with the 127"
on the Burb?
Look's like a Good Start................
Rick
toomanytoyz is offline
Old 04-10-2007, 03:28 PM   #264
quadiak
quadiak's Avatar
I haven't shortened the wheel base yet, I am starting with the body mounting, did you just move the spring perchs ahead to make up for the 4"? Doesn't look to bad kinda getting used to drilling, grinding and hammering rivets out anyway, lol.
I am in the process of moving the rad support mounts back 2" and mounting the original ones from the burb. then I plan to use the ones I removed from the 4x4 frame as the first cab mounts moved 2" forward. looks like everything will fit but i need to add another reinforced brace for the front spring perch(it was part of the old mount i took off).
I am actually kinda curious how it will look with the extended wheel base, maybe I will modify a sideways teardrop wheel opening and leave the axle where it is as long as i put big enough tires on to make it look like a hotwheels toy.
quadiak is offline
Old 04-10-2007, 08:44 PM   #265
toomanytoyz
Luv the Crewcabs
That's all i did was move hangers forward....................
Way that's setting now look's like u could get about 35's on it with no more Lift, Think i will go with 4' lift & 33's on mine. Most of my project is just stuff i have sitting around, Just a low buck build
Old 04-14-2007, 05:32 AM   #266
blackrider
Roll with the punches
blackrider's Avatar
This one is mine.
1972 4x4 suburban (Squashed)
1978 Deville
1978 Allegro RV (For Sale)
"What the mind of man can conceive, It can achieve."
blackrider is offline
Old 04-14-2007, 10:04 AM   #267
shaneschevys
Its always something!
shaneschevys's Avatar
Here is my wifes 72 & my newly adopted 69.
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline
Old 04-14-2007, 09:53 PM   #268
royo
royo's Avatar
Originally Posted by seth 69 sub View Post
heres my 69 it not much now,but just wait,i will post more pics as it comes along,o ya it is my daily driver two
hello what a arms are those they look like cpps
nickle and dime
royo is offline
Old 04-16-2007, 01:40 AM   #269
69face
69face's Avatar
I THINK YOUR UPPER CONTROL ARMS ARE MOUNTED INCORRECTLY. THE ALIGNMENT TABS GO BEHIND THE ARM TO ADJUST FOR CAMBER AND CASTER.
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness!
my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal:
I'M SO SO CAL!
69face is offline
Old 04-20-2007, 08:07 PM   #270
68396
See it here:
http://67-72chevytrucks.com/vboard/s...93#post2129193
68396 is offline
Old 04-26-2007, 04:07 PM   #271
cornfed
cornfed's Avatar
[IMG][/IMG]
Whats left of my suburban - Narrowed 20" at the grille, 30" at the rear, shortened about 28". I've had it for about 7 years now and it just gets smaller all the time. Started out a super rusty $600 project and I think that was the cheapest part yet.
68 blazer buggy
68 stepside
58 gmc
cornfed is offline
Old 05-09-2007, 04:44 PM   #272
bubbaNcolo
Originally Posted by blackrider View Post
This one is mine.
Blackrider
Did you use a template for your camo paint job?
I've got a 71 3/4 4X4 which was camo'd out with paint cans. Need to redo her with a real camo pattern or ?
1971 Suburban 3/4 axles needs a lot of rust replaced
bubbaNcolo is offline
Old 07-07-2007, 09:26 PM   #273
CG
BlahBlahBlah
TTT...how bout some updates on work you guys have been doing on these burbs. Lots of old building threads in this post.
CG is offline
Old 07-09-2007, 03:22 AM   #274
prairewolf
Before and after paint pictures.
I had the antenna base nob removed from behind gas cap, all mirror holes filled in. I have not figured out my side view mirror replace yet, I may go with the little ones I see on some trucks, that mount towards top of vent window, till then I will keep looking over my shoulder a lot.
Mechanically all I have done is baught good plug wires,cap and rotor,... that alone was night and day difference, I have checked all fluids for full and color.
A guy I know sold me a complete set of 94" chevy steel wheels with all caps , rings and lug nuts for 10$. I may just go with the wheels with out caps, rings, just to have more tire options. One post on this site said the off set was goofy so I have to think it through, I have found a good set of tires in 16.5 though,so we will see.
the previous owner took really good care of it so I have time to drive it and enjoy it.
I did notice at some point the pass. side front door was replced, ( no tell tale screw below vent window ) but door works great and I think of this site when ever I look at it. lol. thanks for listening.
p.s this sub will never, ever see road salt again
life is good,kent
prairewolf is offline
Old 07-09-2007, 03:58 AM   #275
prairewolf
p,ss ... I also have a wild hair idea to have buddy buckets front and rear in white leather, but that may just be the good coffe talking.
Closed Thread
