Old 11-22-2002, 08:43 PM   #1
chevjayfsd
Project 7dos
chevjayfsd's Avatar
12 bolt 3.73 Carrier Series????
Summit sells Richmond 3.73's in a 3 series carrier and a 4 series carrier...Which one do i need for my now 3.07 12 bolt??
and do i need to buy 3.73 posi gears or do i just get 3.73 gears, or is there even an option, are all 3.73's the same???
I hope i was clear...And where can i see a full line of EATON products online????
Jason
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
PSSST - Yes it's bagged.
7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290
chevjayfsd is offline   Reply With Quote
Old 11-22-2002, 09:30 PM   #2
Shane
Shane's Avatar
What about the set of 3:73 N.O.S. GM gears i offered?
You sent me a PM saying that you wanted them......but havent hear anything back from you since......
Shane is offline   Reply With Quote
Old 11-22-2002, 10:22 PM   #3
chevjayfsd
Project 7dos
chevjayfsd's Avatar
Sorry I left you hanging.
My dad says he will get everything we need here in town...
But thank you very much for your time
Jason
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
Old 11-22-2002, 10:50 PM   #4
crazy longhorn
Fabricate till you "puke"
The factory put the 3.73s on a 4 series carrier. If you already have a 3 series posi carrier, you need the 3.73s designed for the 3 series carrier. If you are purchasing a posi, I would go for a 4 series unit, & 4 series gears....crazy AL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-22-2002, 11:04 PM   #5
chevjayfsd
Project 7dos
chevjayfsd's Avatar
I forgot one thing though..
I have never seen a positraction for sale, I mean just the posi...Where can i see one and where is the best and cheapest place if any to buy one.???I do have the summit and Jegs catalogs..
Jason
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
Old 11-23-2002, 11:41 AM   #6
chevjayfsd
Project 7dos
chevjayfsd's Avatar
ttt
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
Old 11-23-2002, 02:11 PM   #7
1971LT1SWBPOSI373
1971LT1SWBPOSI373's Avatar
If I remember correctly (because I have already gone through this) there is a slight difference between the carriers and the ring gear diameters. Summit Racing can set you up but you will need the number off of your differential, on the top right inboard axle housing. I used Summit Racing and Richmond gears and everything worked out fine.
1971 Shortbed 350/350 w/ Posi-traction 3:73's
1996 Chevy Silverado
TJ in Springfield, Virginia
Likes old Chevy trucks
Drinks Miller MGD
1971LT1SWBPOSI373 is offline   Reply With Quote
Old 11-23-2002, 06:31 PM   #8
72ChevyCheyenne
72ChevyCheyenne's Avatar
Carrier and Gears
I have a Gov Lock 3 series carrier and a set of 3.73 gears for sale. The gears do NOT fit the carrier. Let me know if you are interested.
Bill Durham
http://home.attbi.com/~bulldurham
72 Cheyenne
Restoration in progress
Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed.
72ChevyCheyenne is offline   Reply With Quote
Old 11-23-2002, 06:44 PM   #9
crazy longhorn
I dont like to cause prob's....but toss d@mn that gov lock in the trash & get on with your projects! it junk.....period! Spoken with all the honesty that i have.........69 longhorn
Old 11-23-2002, 07:04 PM   #10
72ChevyCheyenne
Why do you think I put an Eaton in mine!
Bill Durham
72 Cheyenne
Old 11-23-2002, 07:44 PM   #11
crazy longhorn
My guess, for the same reason Im runnin that eaton ......they work........longhorn
