Old 03-16-2007, 08:46 AM   #1
68_Step
Motor Identification
I have a 67 Chevy C10 that is currently having timing problems. I have had this truck a couple years and have never verified what motor is in it. Considering I might be buying distributer parts soon, I better figure it out quick. The PO replaced the motor in 94 with (according to the Western Auto receipt that he gave me) a 1975 Chevy 350 2 bolt main. My primary confusion is that is has an oil filler tube in front of the carb. I have been reading about the differences and similarities of the Chevy 350 and Olds 350. (1) Olds starter on driver's side, mine is on passenger, (2) Olds oil filter on passenger's side, mine is on driver's, (3) Olds separate oil filler tube on front of block above water pump, well mine has this...
Do I have a Chevy 350 or an Olds 350? Pic is attached.
Thanks for your help!
68_Step is offline   Reply With Quote
Old 03-16-2007, 08:49 AM   #2
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: Motor Identification
Its a small block chevy with the old style intake manifold. The replacement engines usually don't come with the intake, carb, dist, exhaust manifolds because the originals would have been transfered from the old engine to save money.
HG
hgs_notes is offline   Reply With Quote
Old 03-16-2007, 08:50 AM   #3
manimal
manimal's Avatar
-Lance
manimal is offline   Reply With Quote
Old 03-16-2007, 09:11 AM   #4
3/4tonterror
3/4tonterror's Avatar
what they said is right. chevy with old parts on it.
3/4tonterror is offline   Reply With Quote
Old 03-16-2007, 02:22 PM   #5
hyarbour
If you get the casting number and the serial number off the front pad and go to www.mortec.com you can find out what it is.
hyarbour is offline   Reply With Quote
Old 03-16-2007, 03:04 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
yep... you still need to make sure what engine is under those old parts... but that's probably exactly what happened.
Old 03-16-2007, 03:57 PM   #7
68_Step
Front pad: Front passenger side of motor, on block right below the head? Will I need the casting numbers too? They are on the back of the block, drivers side, correct?
Thanks!
Old 03-16-2007, 05:57 PM   #8
john
member #16
john's Avatar
Thanks!
correct. Mortec will tell by casting no's and http://www.nastyz28.com/decode.html will decode the suffix on front pad.
john is offline   Reply With Quote
Old 03-16-2007, 07:30 PM   #9
NPilot1975
NPilot1975's Avatar
If you are buying a distributor your motor, take the old parts or your truck in. It definitely has a HEI distributor from your picture, which means the ignition has been updated.
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 03-17-2007, 08:06 AM   #10
68_Step
Originally Posted by hgs_notes View Post
Its a small block chevy with the old style intake manifold. The replacement engines usually don't come with the intake, carb, dist, exhaust manifolds because the originals would have been transfered from the old engine to save money.HG
hgs_notes: When you said "old style" intake, did you mean old as in old, or old as in Oldsmobile?
Everybody thanks for all the info. I will work on getting those numbers tomorrow. Today is ice storm clean up day. The only motors I will see today is the Ford tractor and the Stihl chainsaw!
Old 03-17-2007, 08:07 AM   #11
krue
Designated A-hole!
krue's Avatar
Old style chevrolet intake.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
