Old 03-17-2007, 09:37 AM   #1
72step
72step's Avatar
Aluminum Intake Manifold Cleaning Ideas?
I'm waiting for a new carb on order, and wondering if anyone has any tricks to clean an aluminum intake. Mine's been there 10 years, and has some baked in oil stains and such, and am wondering if there as any easy way of cleaning it without having to take it off and down to a machine shop so they can dip it in vat? Thanks.........
72step is offline   Reply With Quote
Old 03-17-2007, 09:57 AM   #2
herb101
Used Register
herb101's Avatar
Re: Aluminum Intake Manifold Cleaning Ideas?
You might try brake parts cleaner or straight acetone. Be sure the motor is cold, as the acetone (also an active ingredient in the brake cleaner) flashes off fast already - even faster when warmer.
If you do take it off, a bead blast session will make it look great.
Herb
herb101 is offline   Reply With Quote
Old 03-17-2007, 09:59 AM   #3
RustyParts
RustyParts's Avatar
I use a sandblaster to clean mine make sure you cover the machined surfaces with duct tape before you do.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 03-17-2007, 10:09 AM   #4
72CSTC5
72CSTC5's Avatar
I have used that Eagle One Aluminum Mag Wheel cleaner. It was awesome but burned your eyes if you sprayed it and the wind was blowing. Try it can't hurt.
72CSTC5 is offline   Reply With Quote
Old 03-17-2007, 10:15 AM   #5
zacut
67 chevy SWB Fleetside
Any foundry in your area that makes cast aluminum or cast iron part will have a wheelabrator. If you take it off this is much better than sand blasting. It will be pelted with vrey small steel shot. Cleans aluminum beautifully and leaves absolutely nothing behind to contaminate the engine.
67 Chevy C10 Short Wide
350/350 ... Front Discs ... ECE Lowered 2.5/4
Vintage Air ... Oak Bed Floor ... Painless Wiring
Brothers 1 pc Windows ... Lokar Pedals, Shifter, E-brake
Ididit Column ... VDO guages
zacut is offline   Reply With Quote
Old 03-17-2007, 11:01 AM   #6
hgs_notes
GEARHEAD
hgs_notes's Avatar
Hot Rod magazine has a product they just did a brief article on, let me grab it.
OK, it's Jakel Products Metal Cleaner. They tested it on a dirty edelbrock intake manifold and were happy with the results.
HG
hgs_notes is offline   Reply With Quote
Old 03-17-2007, 12:07 PM   #7
stepside454
stepside454's Avatar
Yep, this stuuf works good, if its not a polished intake, get the self etching version, works real well
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
Old 03-17-2007, 12:18 PM   #8
Wootdog
Wootdog's Avatar
Try Flitz. It will clean up anything. Kerry
1967 C10
Got it back after three years
Boy I sure missed Peppy
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
