Old 03-19-2007, 11:06 AM   #26
Zumo
Hot Rods For Life
Zumo's Avatar
Re: lwb to swb frame chop many pics
Looks very good. Show us pics when you get the plates in.
1968 C10 LWB ****SOLD***
Andy
Viva Los Bicicletas!
Los Muertos Custom Bicycles
Zumo is offline   Reply With Quote
Old 03-19-2007, 02:20 PM   #27
speedracer
Blank
speedracer's Avatar
anyone ever make a short long bed, something inbetween the two that you'd have to look twice to notice??
1969 lwb 4/6 drop 17x8-18x10 torque thrust II's 327-420hp 2004R 3.73 posi.
1977 Corvette 350-375hp 4speed, silver show car.
2002 S10 xtreme, work truck
2004.5 VW jetta GLI 1.8T 6speed, weekend warrior.
2013 Audi A3 TDI, the wife's car
speedracer is offline   Reply With Quote
Old 03-19-2007, 02:41 PM   #28
72chevy327
a 7ft bed that would be different.it might not be too bad cut mabe 6" out of the front and 6" out of the back. some one should photo shop that.
72chevy327 is offline   Reply With Quote
Old 03-31-2007, 06:39 PM   #29
Ram-Man
Ram-Man's Avatar
Finally got this thing back to what it looked like before I got a wild hair and decided to chop it in half. Here are some more pics.
Porterbuilt 8 Lugger
http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
Old 03-31-2007, 06:40 PM   #30
Ram-Man
Ram-Man's Avatar
2 more
Old 03-31-2007, 06:48 PM   #31
72CSTC5
72CSTC5's Avatar
Hey that turned out nice. I like it. Did you bolt in the braces from Early Classic?
72CSTC5 is offline   Reply With Quote
Old 03-31-2007, 06:51 PM   #32
Ram-Man
Ram-Man's Avatar
I did bolt in the braces from ece. My only complaint from the braces is the first set was 3/16" to wide to fit in the channel and the second set was a little snug so I had to do a little grinding on them also. This thing seems very strong now though.
Old 03-31-2007, 07:21 PM   #33
Rokcrln
Rokcrln's Avatar
Yep and here's a pic! It is a SBLWB (short bed long wheel base)! It is a LWB frame with a short bed rear end
Then I finished the short bed conversion.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 03-31-2007, 11:08 PM   #34
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Ram-Man you do amazing work. Thanks for the progression pic's. Every thing looks awesome. yours too Kevin. RJ22
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 04-03-2007, 11:03 PM   #35
ramac1972
how much do you does anybody think a a shop would charge for something like this ?another question would a shortbed bed fit right in or would it take alot modifying
ramac1972 is offline   Reply With Quote
Old 04-04-2007, 01:07 PM   #36
Ram-Man
Ram-Man's Avatar
I think I saw a post where someone spent $500 to have this done when it was a rolling frame. Alot of factors come in on the price though. Is the truck complete or tore apart? If its complete alot would have to be done like shorten brake lines, fuel line, drive shaft, etc. This still needs to be done but when it is a frame off project it is alot easier. Another thought would be to find a shop that specializes in custom work alot of shops might run from work were the thought of cutting the frame in half is involved. Once it is shortened and a couple of cab mounts moved a short bed should bolt right on "famous last words". I will be going the "bed in a box" route. Not many clean short bed donors around here.
Old 04-04-2007, 02:04 PM   #37
Frizzle Fry
Frizzle Fry's Avatar
Looks too easy I've been planning that exact same thing; ECE boxing plates and all... Well done!
Frizzle Fry is offline   Reply With Quote
Old 04-04-2007, 08:06 PM   #38
otsenre
otsenre's Avatar
Nice job on your frame, now I am jealous
otsenre is offline   Reply With Quote
Old 05-21-2007, 10:14 PM   #39
Hart_Rod
Hart_Rod's Avatar
Hey guys, sorry to bring up an older thread, but I have a quick question. I started building my 67 Crew Cab frame this weekend using this post and several others (ROKCRLN) as quidance. I basically took 2 frames (the front of a LWB/and the rear of a SWB) and cut it so I had an extra 33" between the cab mounts when I was done. I've got everything done but the installation of the ECE strengthening plates. The question I have is in regard to adding radiuses to the outside edges of the ECE stiffining plates. Would this maintain the strength/rigidity but add a bit of flexibility? I've read that these plates can cause weakenesses to the frame because they are too rigid. Maybe there's a good reason for not doing it, but I thought I would ask. Here are some pics of what I'm talking about plus some pictures of the CrewCab frame.
Hart_Rod is offline   Reply With Quote
Old 05-22-2007, 12:27 AM   #40
Rokcrln
Rokcrln's Avatar
That is why I did not use the C plates but flat fish plates instead. I think you are fine both ways so it comes down to personal opinion. If you are real good at welding (I am a cert welder for over 17yrs now) and trust your self that a flat plate done right is fine. If you are decent to OK at welding I would go for the C plates.
So is that your home shop or?
Kevin
LFD Inc.
Old 05-22-2007, 12:35 AM   #41
Hart_Rod
Hart_Rod's Avatar
Kevin
LFD Inc.
Shop belongs to a good friend of mine (60 X 40 with 27' semi-down draft paint boot, ). He's the one that painted the 48 and will be painting the Burb. So what do you think about radiusing the plates?
R
Old 05-22-2007, 12:47 AM   #42
Rokcrln
Rokcrln's Avatar
R
I dont think it will make a differance, but the radius would look better.
Nice friend!
Kevin
LFD Inc.
