Old 03-20-2007, 09:44 PM   #1
Zilverado
Zilverado's Avatar
Plug Wires and Distributor Cap Question
So, a couple of questions about the my plug wire and dist. cap/rotor replacement...
Plug Wires:
I got a set of 8 Bosch wires. All wires have 90* boots on both ends except 2. The second shortest wire and one of the longest ones have a straight boot on the plug end. Is this right? Should only 2 have a straight end? If so, which plugs do these 2 wires go to?
Distributor Cap:
The new cap and rotor kit came with a small package of what I assume is di-electric grease? If that's what it is, where should this be applied? Just on the exterior spade connectors to the coil - or inside the cap as well?
Any suggestions here?
Zilverado is offline   Reply With Quote
Old 03-20-2007, 10:30 PM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: Plug Wires and Distributor Cap Question
Can't help on the wires because of so many different brands, I bought Accells for mine and they were all the same.
But,
When you remove your coil from the old cap you will see a round rubber washer in the center. Open the grease and smear a coat ALL over this rubber washer then re-install it in your new cap. This helps prevent arching inside the cap in the coil area, If you have any left add a little to your power wire connector terminals.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 03-20-2007, 11:58 PM   #3
Zilverado
Zilverado's Avatar
Excellent - thanks Man!
Actually, I did a little looking on line and found a few sets of wires that had the 2 straight ends and the rest 90*, so I guess they are right - I just don't get why 2 would be different???
Old 03-21-2007, 12:05 AM   #4
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
For the wires what i did was for the straight, I used the long one for spark plug number 1 and for the short one spark plug number 8.
and for the cap what he said.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 03-21-2007, 03:16 AM   #5
84slopwaggin
84slopwaggin's Avatar
I believe the spark plug wires come like that when they are universal. Usually the ones you buy from Part house come like that unless it's Accel, Moroso, Mallory, etc.
85 LWB Chevy 350/350stocker with Hooker headers dual Magnaflow mufflers upgraded rearend with Eaton Posi unit with 3.42 gears needs interior work(now my DD)
96 Silverado Xcab mild drop(SOLD).
84slopwaggin is offline   Reply With Quote
Old 03-21-2007, 09:52 AM   #6
Zilverado
Zilverado's Avatar
Originally Posted by Restrorob View Post
...When you remove your coil from the old cap you will see a round rubber washer in the center. Open the grease and smear a coat ALL over this rubber washer then re-install it in your new cap. This helps prevent arching inside the cap in the coil area, If you have any left add a little to your power wire connector terminals.
Duh - - I should maybe read the instructions. After I posted this last night, I remembered that there was a small paper that fell out when I remove the dist cap from the box. Instructions perhaps? Yup - and they say exactly what you just said.
Originally Posted by Srubydo1986 View Post
For the wires what i did was for the straight, I used the long one for spark plug number 1 and for the short one spark plug number 8...
Yeah, that's what I was thinking of doing - since 1 is a long wire and 8 is a short one.
Thanks guys.
