Old 03-20-2007, 11:02 PM   #1
bigblock73
yeller
bigblock73's Avatar
Power steering box question
How can one tell which port the high pressure hose hooks to from the power steering pump? I am assuming it is the one on the top of the pic below.
Also, I purchased both new hoses, one has the fitting on both ends (high pressure hose, supply I 'spose), the other for all intensive purposes is just a hose that is secured with hose clamps (low pressure hose, return). I assume there is a fitting I need for the low pressure hose, but I do not have one and don't remember if I pulled one off six years ago when I tore the truck apart. Can someone tell me what I need exactly so I can go about getting it?
bigblock73 is offline   Reply With Quote
Old 03-20-2007, 11:07 PM   #2
BaddBusa2005
BaddBusa2005's Avatar
Re: Power steering box question
being you have the hoses, the hose ends on the hoses are different sizes at the box.
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq
BaddBusa2005 is offline   Reply With Quote
Old 03-20-2007, 11:11 PM   #3
bigblock73
yeller
bigblock73's Avatar
But are the two ports on the box the same size...I think they are (cannot verify unless I trek back out to the garage)? I was just wondering which one on the box was the supply port.
Old 03-20-2007, 11:24 PM   #4
swervin ervin
You get what you pay for
swervin ervin's Avatar
Jeff, here is an old pic of mine. You can see what you need I think.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 03-20-2007, 11:28 PM   #5
bigblock73
yeller
bigblock73's Avatar
Thanks Mike, exactly what I needed!!
Now I just have to track down that tube for the return.
Old 03-21-2007, 12:40 AM   #6
Russell
Professional Grade
Russell's Avatar
Yep, pressure side is the port closest to the frame.
Did your new hose not come with the steel part?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-21-2007, 06:52 AM   #7
bigblock73
yeller
bigblock73's Avatar
The supply hose had both ends crimped on and has everything I need to hook the pump up to the box, the return was just a hose with clamps on it. I did find the tube for the return in my stash of parts, so everthing is now accounted for.
Thanks again for the help.
Old 03-21-2007, 11:23 AM   #8
Russell
Professional Grade
Russell's Avatar
She is definitely getting closer How long till the first drive?
Old 03-21-2007, 12:55 PM   #9
bigblock73
yeller
bigblock73's Avatar
A little while yet...but not far. I may end up driving it by mid summer...we'll see.
Old 03-21-2007, 02:29 PM   #10
Russell
Professional Grade
Russell's Avatar
Cool, mine might hit the road again about the same time... Need something powerful enough to haul 7 - 8 quads this summer, don't think the 4.3L in the K1500 is up for it
