Checking interest in a near perfect 67 big window air cab.
This truck should be sold as a whole truck but I will part it out if I need to. The truck is a 67 CST big window 327 auto air. Pretty much a complete truck minus the tailgate and buddy buckets. I dont have a title for it but someone in another state should be able to get one. It has not bee registered since 73and has a lean on it.
I know I can sell the 327 locally with no effort, but if some body here wants it I dont have a problem with that either. The front clip is very nice and will sell easily. The cab is the nicest cab that I have seen in 16 years that I have been dealing with these trucks and the doors are equally nice. I am sure there are nicer ones out there, but I have never seen one. Qksilver has first shot at the whole truck and kbs71 at the front end clip. The rest is as follows. Truck ..$1800 Front end clip .. 500 Cab w/o doors .700 w/doors 900 Doors ..150 each Complete 327/trans ..450 Unless someone wants the cab I dont think I will part the truck out at this time.
72 Cheyenne Super 80 Silverado Blazer 2wd |
Re: Checking interest in a near perfect 67 big window air cab.
I need to double check but I think the only rust on the cab is these few spots on the passenger cab corner.
do you need it gone now or could you hold it for a bit?
Space wise I can hold it it forever, $$$ wise I need it gone!
if someone beats me to this one do you have any other cabs you would part with? maybe a little cheaper. i just need one thats restorable and is better than what i got. right now i only have 400 so i couldnt get it for another 2-3 weeks.
OMG look at all those cool trucks. TTT for you.
"You can take the man out of PA, but you can't take PA out of the man" Last edited by HeavyD; 03-21-2007 at 01:30 AM. |
I have several good cabs that need the rockers and corners replaced that would be cheaper.
Does the clip have any damage or rust?
"You can take the man out of PA, but you can't take PA out of the man" |
The clip has one dent and one small rust hole in an odd place at the rear of one fender. The grill is near perfect with the exception of two holes for the grill guard. I have several other grills if that is a problem. The inner fenders are rust free.
PM sent on complete truck.
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" |
![]() Join Date: Apr 2005
What shape are you other grilles in?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
If you part it id take the A/C BRACKETS FOR SMALL BLOCK, PM me if you do. thanks
if you part it and the side trim isnt going with the front clip i would like to be first in line.
Josh |
Can you PM me, wasn't sure what was up, so I haven't been in contact with you.
I will be home after 9 pm tonight. Definity want it but just have to work out some details Thanks, Steve Last edited by qksilver; 03-21-2007 at 09:18 AM. |
#15 |
Born Psycho
![]() Join Date: Feb 2001
i still see the back rest bracket for the buddy buckets on the back of the cab.i've parted several 67 CST's with the big back window and most had buddy buckets and speedwarning, not sure if it's commen elsewhere or maybe a local thing.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
#16 |
Engine and trans interest.
Does the engine spin or is locked up? What type of trans - TH350?
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
#17 |
HOT FUN.... you are 2nd inline for the truck.
ROB........... I have at least three other grills that are in very good shape,but no good pics yet. 3/4 TON......I might have a set on another truck. I'LL check for you. JOSH..........You are 1st inline for any side trim I part with STEVE........I'll PM you. JERRY.........You are probably right about the buckets/speed warning in these CST's. Both the original cluster and the seats were stolen from this truck before I got it. I found the identical twin sister CST to this truck that I am trying to buy, and the buckets are also missing but it has the speed warning. CHAD...........I need to double check to see if it will spin. I have been told that 327's came witha TH400 but I have not checked. If not it is a TH350
#18 |
If you part I'm interested in the CST horn button, the radio knobs, other knobs, possible vent(wing) windows, maybe the grill guard.
Thanks - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
#19 |
Here is a pic of the door panels that someone wanted to see.
#20 |
I want that cow catcher on the front!!!! How much?
Even the nicest dodge-chrysler is only 2years away from being parked outside of Section 8 housing. |
#21 |
Mark, When do you want the truck delivered? PM or call me.......Jason
#22 |
Jason
Great talking to you and the check is in the mail this afternoon for the complete truck and dash pad. Mark
#23 |
Sounds good! Now that that deal is done, why don't you go ahead and bring down that 72 Cheyenne k10 swb when you come and I will take it off your hands.
