03-21-2007, 06:29 PM | #1 |
tilting a 71 seat
Is there a way to tilt a 71 bench to allow access to behind the seat area? I removed my stock tank and would like to use the storage space back there.
Got a good bench seat just want it to tilt forward. |
03-21-2007, 06:40 PM | #2 |
Watch out for your cornhole !
Re: tilting a 71 seat
There's two bolts on each side that hold the back to the bottom. You'll remove one from each side and it will now pivot on the remaining one.
03-21-2007, 07:43 PM | #3 |
70+ ( Old Skool Club )
Glad to see you back on the site Kevin.. Your knowledge, expertise on our trucks and willingness to share the info with anyone is much appreciated.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
03-21-2007, 09:36 PM | #4 |
On my old truck I used one of those round pins withe the pball bearing in the end in that bolt hole. Pulled the pin and the seat went forward. Put the pin back and the seat doesn't hit the back oof the cab. Just my 2 cents!
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
03-22-2007, 12:55 AM | #5 |
I used to do the same thing as Jorgensensc when I was in high school, but it was to hide my... um... oregano. Hit a Tractor Supply and go to the trailer area....remove the front pair of bolts and the pin solution works great!
