Two PVC?
I have an open element air filter. one valve cover has a PVC valve the other a push in breather.
What if I had a PVC valve in each valve cover? then run 3/8 vacuum hose to a T, then to the carb? Would that be good/bad/wouldn't hurt? Thank you
79 Blazer Cheyenne, 2wd 305 3.42 stock 85 Caprice, TBI converted, new 350 crate motor, Monte Carlo SS Wheels, Bilstein shocks, |
Re: Two PVC?
In order for PCV to work correctly you have to have somewhere for air (preferably filtered) to enter the crankcase and then drawn into the carb carrying with it fumes to be burned in the combustion chambers. Creating high vacuum in the CC could cause seal failure at the crankshaft sucking undesirables into the engine there.
Oscar '72 Shortbed Fleetside '95 Jimmy 4X4 '69 GMC Custom Camper |
Re: Two PVC?
That makes sense. I would think the seal would be tough, but the idea is to keep the engine as durable as possible.
sufficiently talented fool
![]() Join Date: Jun 2006
Re: Two PVC?
Also, a PCV is a metered air leak, installing two of them may create high idle problems. I would recommend leaving it alone. Just my opinion.
"it's impossible to be surrounded by idiots when you are part of the circle" ![]() 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
Re: Two PVC?
Here's an article that explains fully the actual designed purpose and function of the system.
PCV theory
