03-25-2007, 12:40 AM | #1 |
Is cutting your stock
......springs safe? Want to lower my truck next weekend. And thought about just cutting the springs down.
1971 Chevy C-10 . |
03-25-2007, 12:43 AM | #2 |
Texas Big Wig
Re: Is cutting your stock
As far as I know, the only problem is if you don't safty wire them in & you hit a big bump they can jump out
And they don't ride very good, but that don't matter Last edited by Spray-Bomb; 03-25-2007 at 12:44 AM. |
03-25-2007, 12:48 AM | #3 |
Too many projects
Just cut them with a cut off wheel and not a torch. The heat from a torch can mess up the spring rate and safety.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
03-25-2007, 12:49 AM | #4 |
Dont do it the redneck way...save up and buy the right springs and do it right.
03-25-2007, 01:00 AM | #6 |
As far as best bang for the buck can you point me in the right direction?
1971 Chevy C-10 . |
03-25-2007, 01:03 AM | #7 |
GEARHEAD
Here's my veiw on the subject. It should not be done. BUT BUT it has been done by more people than you will ever know. I myself have done it not on a street driven vehical but on race car springs. I have never had anything bad happen but, there are people that have. Which is precisly why it is not recommended.
So if you do decide to do it do as lowrollin70gmc said and cut with a cut-off wheel not a torch as the heat will ruin the integrity of the spring. You may cut what you think you need off and lessen the spring rate at the same time compounding the effect. You can even do it in steps to keep the heat out of the rest of the coil. Don't go and throw water on it to cool it off faster either as it's just wrong phyisics involved there. I'm not telling you this to say its right but if you do decide to to take as many precations as you can to be safer. weeeeew that being said I agree with 1969k10stepside you really should just save up and do it right.RJ22
72 SWB 2WD MY PROJECT 72 LWB 4X4 FUTURE PROJECT SUBSCRIBE HEREBOARD VENDORS HERE NORWOOD MEET SURVIVOR! Last edited by RACINJASON22; 03-25-2007 at 01:05 AM. |
03-25-2007, 01:06 AM | #8 | |
Here is some for the front that were for sale,I believe they are sold now link Last edited by 1969k10stepside; 03-25-2007 at 01:06 AM. |
03-25-2007, 08:29 AM | #9 |
Cutting springs ruins the integrity of the spring-rate.Take that torch and heat them to lower.They will be safer and either way,you`ll save your money faster for those new drop springs and spindles.
To do it right you`ll spend $800.You can get away with less w/o an adjustable panhard and shock relocators.I`m talking about a 4/6 drop.
03-25-2007, 04:56 PM | #10 |
Watch out for your cornhole !
I've been cutting springs since the mid 80's. Never had a problem. All my trucks now have cut springs and I drive them daily.
03-25-2007, 10:19 PM | #11 |
personally,...
With the surplus of drop springs from parts house & catalogues, they ( front & rear ) are SOOO cheap,( most aftermarkets are $99 / pair ) plus you can have each side match in drop.... frankly ,..It's like ' safety in the bank ', I know it's far easier to align, & control tire wear, steering & at speed. ! also I think your insurance co. would fry you, if you were ever in any kind of accident because of cut springs, but,.... just my two pecos,.. -41-
1941 Chevy 1/2 ton Street Rod: 327 cu,/350 auto, 'Stinger ' - JULY 2007 CUSTOM CLASSIC TRUCK magazine. 1967 Chevy 3/4 ton standard bed, 350 cu./400 auto, w/ 83 - 3:43 rear end...sips gas.... Last edited by fourty1; 03-26-2007 at 12:39 AM. |
03-25-2007, 10:33 PM | #12 |
I've got 3in front and 5in rear drop springs and shocks in my truck from Classic Performance Parts, and they ride as good if not even better than stock...cutting springs is ok to see what a certain drop will look like and such, but as the others say, the integrity of the spring metal will be compromised, and all it takes is one mishap.
'69 C10 350/3spd dropped 3/5, 93 Stepside bed...was my highschool project, but now it's gone to college with me |
03-25-2007, 10:37 PM | #13 |
http://www.classicperform.com/Store/.../6372CSSKD.htm
link to above coil springs...can be ordered seprate for 95.00 a pair, they come powder coated (not crazy about the colors...mine were light blue for the rear and dark green for the front) shock kit can be purchased seprate as well for about $130
03-25-2007, 10:45 PM | #14 |
its all about the +6 inches
one man's budget bolt on, is another man's entiure budget.
You can chop the front springs no problem, and I've always been told to use a cutting torch, plus, that's how i did at least 20 pair back in the 90's. They've been hackin them since the 60's. Last edited by Longhorn Man; 03-25-2007 at 10:45 PM. |
03-25-2007, 11:24 PM | #15 |
just dont cut too much off at a time hahaha than your screwed
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4 70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s |
03-26-2007, 07:03 AM | #16 |
I was just saying cutting vs. heating,it`s all the same.You alter the spring`s original function.
03-26-2007, 07:49 AM | #17 |
There is a lot of misinformation here. Magazine articles perpetuate the myth that cutting a spring is dangerous because advertisers sell springs and advertisers pay lots of money to magazines for ad space.
1) A cut spring will align just like a custom built drop spring. Period, end of discussion. The alignment is exactly the same whether it's a cut coil, a lowered coil, or a block of wood. You align the truck at ride height. How you achieve that ride height doesn't matter. As long as your front end isn't excessively worn out, there will be plenty of thread space left on the upper control arm studs for shims to bring the caster and camber back to spec. 2) I cut mine with a die grinder and cutting wheel. The heat generated this way is negligable. You can put your hand on the spring an inch away from the cut and it's not even hot. That's not enough heat to affect the temper of the steel. 3) People talk like it's an accident waiting to happen. Ask yourself, what is the worst possible outcome that could happen if a coil spring fails? Even if it collapsed suddenly while driving, the truck would simply sag down. it's a lot safer than these air bag trucks that are set up to lay the frame. If one of those bags fails, the truck will hit the road at speed. Not the case with a coil. 4) On these trucks, one coil removed equals about 3 inch drop. 5) Cutting one coil is not enough to make the spring loose in the pocket. Two coils will though. No matter what you do to the truck with one coil removed, the spring stays firmly seated in place once installed. 6) I've been doing alignments for 19 years now. I speak from experience, not heresay. 7) I'm going to go get in my truck right now and drive it to the donut shop. I'm confident after driving it 100 miles a day for the last year that it's safe. I'm going to use part of that 90 bucks I saved by not buying coils to pay for my donuts.
03-26-2007, 08:27 AM | #18 |
Happy to be here
Thank you for saving me the trouble of typing all that. Everyone please read Kevins "article" and remember it well. What he says is 100% fact, not rumor, hearsay, or bench racing bullsh!t.
03-26-2007, 08:44 AM | #19 |
To expand upon what has already been said...
The method of heating a spring till it sags is what is dangerous. That removes the tmeper from the steel. Using a torch to cut a spring is ok. I prefer a cutoff wheel. As the spring is shortened, the rate actually increases. However, depending upon the amount of drop, the new rate may not be firm enough to keep the suspension off the bumpstops through full suspension articulation due to the decrease in overall suspension travel now available. I found this online coil spring rate calculator. Try pluging in some numbers and then reduce the "number of active coils" to see what happens. http://www.stockcarproducts.com/pstech10.htm
My 51 project http://www.cardomain.com/ride/2285825 My 68 Camaro project http://www.cardomain.com/ride/2277404/1 Last edited by bretcopsey; 03-26-2007 at 08:45 AM. |
03-26-2007, 09:54 AM | #20 |
Questionable
You need to increase spring tension by 15% for every inch removed. You can't do that with a cutting wheel any more than a torch.
If you cut 'or' torch, the second you bottom out your shocks from bouncing all over the place, be prepared to be spending more money when you blow out your shocks.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 03-26-2007 at 09:56 AM. |
03-26-2007, 10:09 AM | #21 |
Save time & money, just go get some exterior housing bricks from you closest construction project. remove old springs and replace with above confiscated bricks. it'll ride the same, and it'll save you all kinds of time & money...
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
