Old 03-25-2007, 09:57 AM   #1
Jimmi
Need some HEI Help
Howdy all, Working on my uncles 71 3/4 ton with a 402. I am trying to talk him in to buying an HEI. I am tired of adjusting points and dwell lol. I wondering if the big HEI CAP IN COIL will fit fire wall clearance? I know on my Chevelle I have the external coil. I can't seem to find them for sale. If the big cap will fit I will just co with that. Jim
Jimmi is offline   Reply With Quote
Old 03-25-2007, 10:12 AM   #2
3/4tonterror
3/4tonterror's Avatar
Re: Need some HEI Help
Yes it will fit with plenyt of clerance. I have HEI in my 2wd and 4wd, plenty of room.But less room in my 4wd.
3/4tonterror is offline   Reply With Quote
Old 03-25-2007, 10:43 AM   #3
Jimmi
Thanks for the advise! Jim
Old 03-25-2007, 11:42 AM   #4
cdowns
cdowns's Avatar
if he wants to retain the original look/ pertronix makes a really nice billet hei that uses original size and type of cap and uses an external coil/not cheap at over $200 for the setup
Old 03-26-2007, 01:02 PM   #5
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
I have that setup no problem , Here are the spec some of us used to set up the HEI.
When I installed an H.E.I unit in my ( 402 engine) ; I had a distributor rebuild shop set the advance curves as per the GM factory manual. The specs are :- 0 degrees @ 930 RPM; 2 @ 1260 RPM; 16 @ 2400 RPM and 30 @ 4400 RPM. Vacuum advance specs are 0 degrees @ 8" hg and 20 degrees @ 17" h.g. Initial ignition timing is 8 degrees advance @ 600 RPM ( idle speed).
... Above specs are from GM 1971 Chevrolet Truck Service Manual.
... Another GM reference is the 'GM/AC/Delco Tune-up Specs Manual # SD-100. These specs call for a 10-13 degree centrifugal advance @ 2000 RPM and a total advance ( vacuum & centrifugal ) of 28 to 35 @ 2000 RPM...... When I installed my unit about 10 years ago; I used an adjustable timing lite and set the timing to 35 degrees @ 2000.........No problems and I am well satisfied with the engine performance.............
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 03-26-2007, 08:43 PM   #6
mnunn454
mnunn454's Avatar
Large cap HEI fits in my 69 with a BBC.
One point though (no pun intended). The power wire to a points distrib is usually a resister wire that reduces voltage to keep from burning up the points. HEI needs a full 12 volts, so suggest you loose the resister wire if it's there.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 03-26-2007, 09:32 PM   #7
Snew
I did the same swap. I got my wire from Year one. It snapped right into the back of the fuse block and had the correct connector for the distributor on the other end. Really felt like a good job to me.
Snew is offline   Reply With Quote
Old 03-27-2007, 12:50 AM   #8
Bill72BB
Bill72BB's Avatar
Just wanted to mention that the setup figures I posted were from GMC JIM ,one of the few members on this board older than me .
BILL
Member DUF Club
Old 03-27-2007, 01:02 AM   #9
timcos
Chief Honcho In Charge
timcos's Avatar
I did shave off thew rear 1/4 inch of my HEI cap...nothing but plastic shaping and fins.
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
