Old 03-23-2007, 11:30 AM   #1
85_SWB
85_SWB's Avatar
What do you guys think?
heres how my truck sits now.
I did 3" drop coils and a 5" flip kit.
To me it looks like the back is lower than the front.
Now my question is are you guys seeing the same thing and schould I do 2.5" drop spindles to bring the front down a little more?
1985 C10 SWB- *Project*
85_SWB is offline   Reply With Quote
Old 03-23-2007, 11:33 AM   #2
bigblock73
yeller
bigblock73's Avatar
Re: What do you guys think?
Personally, I would have run 2.5" or 3" spindles, and a 1 or 2 inch drop coil. You ideally need about a 4" drop in front to match your rear drop, a 5" front drop to have a slight rake.
bigblock73 is offline   Reply With Quote
Old 03-23-2007, 11:40 AM   #3
85_SWB
85_SWB's Avatar
i wish i would have done spindles first now
i figured 3" drop coils in the front would be enough.
Old 03-23-2007, 11:52 AM   #4
boatpuller
boatpuller's Avatar
yup,i think your gonna have to do spindles to get the look your after.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 03-23-2007, 02:51 PM   #5
hiway
Mad Scientist
Just measure from the ground to the wheel well opening...right in front of your center cap on the wheel. I like them to be the same. If there is any rake to a rig, it should come from the tires height difference only and not the susp. Just an opinion....
Everythang relates to Beer!
86 1/2ton on tons! sbc/465/208/D60/14/35's
81 Postal....with 468 bbc
97 Merc Marq comuter
07 Suburban
02 Danger Ranger
hiway is offline   Reply With Quote
Old 03-23-2007, 03:25 PM   #6
85_SWB
85_SWB's Avatar
i did that before and i was told that the openings are differnt sizes(front and back) so i measured to the body line and the front was 1" higher
Old 03-23-2007, 05:04 PM   #7
benoit454
Chris
benoit454's Avatar
I'm seeing the same thing, back lower then the front. The tires is about to tuck inside the fender in back but not in front.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 03-23-2007, 08:59 PM   #8
Restrorob
The One And Only !!!
Restrorob's Avatar
It's hard to tell with the shadow underneath, But it looks almost level to me looking at the bottom body line to the concrete. (arrows) That may be a better place to measure since the front wheel openings and body line is a little higher in the front.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 03-25-2007, 01:27 AM   #9
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Based on your body line measurement, your front sits 1" higher than the rear. Adding 2.5 drop spindles will give you a 1.5" rake, and tuck the front wheel closer to the wheel well. But, since you're running 15" Modulars, check to be sure you won't have any rubbing up front. It doesn't 'look' like the 3" dropped spring gave you a full 3" drop up front. But it's hard to tell from the pic. Did you, by chance, take before and after measurements?
BTW, it's getting there.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 03-25-2007, 10:23 AM   #10
poolboy65-ls1
iamthepoolboy!
poolboy65-ls1's Avatar
Here's mine with 3" drop spindles w 2" drop coils and a 5" flip kit in the rear. Yours should look like this if you do the spindles.
Black primed 81 Silverado SWB one owner rust free all original 106,000 project. Steel cowl hood, 89/91 front grill, Blazer tailgate trim, sport rear bumper, 5/6 Drop, 17" Eagle Alloys, Big block is on the stand! COMING SOON: one piece glass, and more.
poolboy65-ls1 is offline   Reply With Quote
Old 03-26-2007, 05:34 PM   #11
liljon285
That Guy
liljon285's Avatar
CRAP! I got the same kit for my truck I hope it dont come out like that i kinda want the rake look but i only have 5" flip kit in the back and 3" coils for the front, so if i get 2" spindles ill get a good rake?
1978 Chevy Scottdale Stepside, 3rd engine- 350c.i. built with cam and lifters, holley 670cfm carb. and intake,heads shaved .60. Truck is a project, and I am its restorererer!
liljon285 is offline   Reply With Quote
