Old 03-29-2007, 11:17 PM   #1
isenegger
how to get a 1/2 ton to sit up like a 3/4??
i want my 1/2 ton to sit up like a 3/4 like this......
isenegger is offline   Reply With Quote
Old 03-30-2007, 11:44 AM   #2
Ram-Man
Ram-Man's Avatar
Re: how to get a 1/2 ton to sit up like a 3/4??
we are all about lowering here
Ram-Man is offline   Reply With Quote
Old 03-30-2007, 03:56 PM   #3
isenegger
well then dont input if your not helping
Old 03-30-2007, 08:35 PM   #4
Ram-Man
Ram-Man's Avatar
Chill out Nothing personal most members here make silly comments for fun. I would think you could raise it with either 3/4 ton springs or if you have leafs in the back you could add shackles.
Old 03-30-2007, 08:56 PM   #5
Shane
Shane's Avatar
so put it on a 3/4 frame ...
p.s. you're not gonna make many friends with the pissy attitude.
Shane is offline   Reply With Quote
Old 04-02-2007, 03:39 PM   #6
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
2wd or 4wd?
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 04-02-2007, 05:15 PM   #7
isenegger
its 2wd all im worried about is the front right now. the back will be blocked to level it out
Old 04-02-2007, 05:34 PM   #8
bigbluthng
bigbluthng's Avatar
do you know how much higher it is that you want to go? fabtech makes a 3" lift coil for 73-87 2wd trucks.
bigbluthng is offline   Reply With Quote
Old 04-09-2007, 11:20 PM   #9
t rex 7
t rex 7's Avatar
Check out the fabtech kit, its about 640-750$, a little costly for some you might also check and look at the truckin mag and see the ads for lifts of 3". I went the fabtech route but havent installed the kit yet, waiting till i replace the entire front suspension next month. One of the few C-10s with a fuel injected V8 and 30MPG!!
t rex
t rex 7 is offline   Reply With Quote
Old 04-10-2007, 02:46 AM   #10
royo
royo's Avatar
Hello check around an get you some heavy duty springs or call ece or cpp they have all kinds of springs but a 3/4 spring will ride harsh
nickle and dime
royo is offline   Reply With Quote
Old 04-10-2007, 10:46 AM   #11
martinkh
Find a local spring shop to re-arch your springs.
On my 70 4x4 3/4 ton, I paid $491, tax included, for one day service to have the springs re-arched and have an add-a-leaf 2" lift front and rear. I will never worry about axle-wrap due to rear blocks. For the cost, you can't beat it. Plus, aftermarket springs are usually sloppy, and you will find that you cannot use as large a tire as you thought, and you can really get bouncy. The drawback is a stiffer ride, but better road handling, and your wheels will not droop as deep into gullies when you cross them.
'70gmc 3/4ton 4X4, re-arch and 2" add-a-leaf lift.
'77 400sbc, '82 axles, d60front, 14bolt rear.
Probably some 285/75/16 Toyo m/t's on my stock rims coming up.
martinkh is offline   Reply With Quote
Old 04-10-2007, 11:30 AM   #12
Tony@AirRideTech
Junior Member
Just order replacement springs for a 3/4 ton........ The only thing I would think you might want to double sheck is if the leaf springs are the same length from eyelet to eyelet.
Tony@AirRideTech is offline   Reply With Quote
