Old 04-01-2007, 04:01 PM   #1
corkscrew
What is a cheap way to prevent paint from peeling??
i got a major bad spot but i want to hold off until fall too paint it...what can i do to stop the amount of peelage?
corkscrew is offline   Reply With Quote
Old 04-01-2007, 04:15 PM   #2
cdowns
cdowns's Avatar
Re: What is a cheap way to prevent paint from peeling??
the paint is peeling because of improper application and will continue to peel the only proper way to fix it is to take it off and prep and apply correctly
Old 04-01-2007, 04:36 PM   #3
corkscrew
ok well i bought it with only 2 spots with paint chipped off...over time those spots are getting larger....could i maybe put a little bit of clear coat? Or would that wreck it?
Old 04-01-2007, 05:19 PM   #4
RED72blazer
urban fourwheelin
RED72blazer's Avatar
it's not a matter of putting something over it. The surface under the paint is the problem.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 04-01-2007, 05:22 PM   #5
Pl4yboy
Freeeeee Mason...
Pl4yboy's Avatar
Take all the paint off and put it in some spray bomb primer.
Pl4yboy is offline   Reply With Quote
Old 04-01-2007, 05:25 PM   #6
corkscrew
take the paint off where its bad right pl4yboy???
the paint is fine its just where the edge is....weather water or something else hits it....
Old 04-01-2007, 05:26 PM   #7
masterbeavis
Having issues
masterbeavis's Avatar
thats too much work!. Leave the old stuff and spray bomb over that!!! Some el cheapo clear will slow down the paint flaking off, but wont stop it. It will be more paint you have to strip later.
masterbeavis is offline   Reply With Quote
Old 04-01-2007, 05:31 PM   #8
corkscrew
i never heard of this spray bomb....whats it do and where can u get this?
Old 04-01-2007, 05:35 PM   #9
corkscrew
it is only to last me probably 5 months or so not multiple years....
Old 04-01-2007, 05:38 PM   #10
Rokcrln
Rokcrln's Avatar
Regular rattle can spray paint.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 04-01-2007, 05:47 PM   #11
corkscrew
o wow....i just thought i little bit of clear coat would do wonders, my truck is purple and it would be very hard to match a spray bomb paint
Old 04-01-2007, 06:13 PM   #12
Pl4yboy
Freeeeee Mason...
Pl4yboy's Avatar
Cork... I meant just take it all off... go primer all the way around. Or you could just let it flake it you get a real paint job.
Old 04-01-2007, 06:17 PM   #13
corkscrew
ya thats true
