Old 04-02-2007, 09:51 PM   #1
79underconstruction
79underconstruction's Avatar
bypassing an EGR Valve...
so can it be done? and if so how?
79underconstruction is offline   Reply With Quote
Old 04-02-2007, 10:05 PM   #2
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: bypassing an EGR Valve...
I know edelbrock makes one. For non egr intakes. what the do is just put a block off plate were it would be in the intake. Id surch edelbrock for it cause im shure they would sell it by it self.
What it does ids yoy just remove the egr valve and bolt the plate on it.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 04-02-2007, 10:43 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
Take the EGR off of the manifold and make a flat plate to cover the holes. The EGR takes gas in and out through the holes in the manifold. Don't forget to cap off the vacuum source.
Old 04-02-2007, 11:59 PM   #4
jimfulco
Don't forget, if you're using a carb that's calibrated for use with EGR, you'll likely get some part-throttle pinging if you ditch the EGR.
jimfulco is offline   Reply With Quote
Old 04-03-2007, 05:06 PM   #5
Slonaker
Insert Witty Text Here
Slonaker's Avatar
My EGR had a spacer that went between it and the intake. I used it as a pattern to cut a blockoff plate, then put the spacer on top of the plate to strengthen it up. I then bolted the plate and the spacer in place of the EGR valve. A thicker plate would have worked better, but I used the only metal I had.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 04-03-2007, 07:20 PM   #6
79underconstruction
ok.. i c thanks guys
