Old 04-03-2007, 01:32 PM   #1
stingray72
Red Headed Step Child
stingray72's Avatar
Ooh.. Let's chat drivetrain.. I'm excited
Now that my 70 is sold and my Superhawk should be gone in a couple of weeks I'm getting kinda excited about giving my Jimmy a once over
My dream would be to have it like what you'd see at Barrett Jackson but I know I wouldn't drive it and a trophy I don't want. I want a REALLY NICE rig that I'm not gonna feel bad about taking it out for a cruise.
Right now it's got a 350/350 combo that I'm 99% sure is not original so I'm not really concerned about changing it. What i'm posing to you smart fellers who stayed in a Holiday Inn express last night is what do you think I should do with concerning drivetrain??
Options I've thought about in no particular order are...
A. Keep 350/350 combo, freshen it up, new cams, pistons, heads etc and just drive her.
B. Go with a 383 stroker and a built 700R4 or some other similar tranny
C. Big Block, Big HP who cares about $3/gallon gas
D. Completely updated drivetrain.. LS1/460LE or whatever that tranny is called I don't think that's right to make it so i can drive the truck to Alaska
I'm torn and thought it would be fun to start some chit chat about pros and cons etc of options available (which are limitless I know)..
I'd like to have something that's a little better than 5 mpg so I can drive it around and not watch the gas hand move but I digress..
and b/c I know it'll come up.. lets say I have between 5K and 10K to spend.
"Dinner, the perfect break between work and drunk"
-Homer Simpson
stingray72 is offline   Reply With Quote
Old 04-03-2007, 02:12 PM   #2
Yukon Jack
Yukon Jack's Avatar
Re: Ooh.. Let's chat drivetrain.. I'm excited
Is this a 2wd or 4wd?
How about rebuilding the existing engine and get an overdrive tranny and design it for the use of a not too big turbo. Gain some mileage with the overdrive and have lots of power on tap. Sounds good to me!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-03-2007, 03:00 PM   #3
stingray72
stingray72's Avatar
It's a 2wd and already has a 4/6 ECE drop. I'd love to eventually bag it also.
Anyways.. I like the turbo idea.. but know jack about them
-Homer Simpson
Old 04-03-2007, 03:14 PM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I've always wanted to put a 572 into a '72 Blazer and have custome emblems made that say K/572.
The stroker with the 700R4 would provide nice HP and gears and look impressive in the specs, but it would be more work than just keeping the TH350 behind a nice crate motor (especially if it is a 4wd). Edelbrock makes some great, ready to go motors at fairly reasonable prices and they look nice too.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-03-2007, 03:15 PM   #5
bouncytruck
SKINNY TIRES RULE!
You posted at the same time as me...
Check this out. Solves all your problems at once.
http://67-72chevytrucks.com/vboard/s...d.php?t=234366
bouncytruck 1972 K5
Old 04-03-2007, 03:24 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I really like D, or some version of it, but I can't afford that option
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 04-03-2007, 05:12 PM   #7
see ten
WTB this ad
see ten's Avatar
I had originaly planned on doing a late model swap in my C10. However the truck just runs to damn good to pull it apart. I guess a better question is, Does your engine need built? If everything is still working and you aren't smokin or burnin oil maybe you could just pep it up a bit and spend your excess funds elsewhere. I added an aluminum intake and roller tip rockers and an MSD coil and wires. I also removed the engine driven fan and replaced it with an electric setup. The umph level has really increased and the mileage stays around 14-15 mpg. But yeah if money wasn't an object I would probably have a late model Vette engine and trans in it.
see ten is offline   Reply With Quote
Old 04-03-2007, 06:34 PM   #8
vtblazer
vtblazer's Avatar
My input would be at a minimum, make sure you have fuel injection and an overdrive of some sort.
That alone would be a great start to a very drivable/fun ride.
vtblazer is offline   Reply With Quote
Old 04-03-2007, 07:29 PM   #9
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by stingray72 View Post
D. Completely updated drivetrain.. LS1/460LE or whatever...
Once you go this route, you will never look back. It is really not that expensive if you do your homework and save where you can. I have made it my goal to do it for less than the cost of a 383 with more power/better reliability/mileage. Plus, the wow factor exponentially increasees when you pop the hood.
-Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-04-2007, 12:12 AM   #10
72LoBurb
Yup, I'm comp-useless
Even a newer LT-1, with an overdrive trans...lots of power potential, the advantages of injection and o/d, plus you shouldn't have to be fabbing or buying special motor mounts.
I plan on this swap in the not-too-distant future, by finding an old Caprice(94-96) to use as a driver for now and a donor for later.
72LoBurb is offline   Reply With Quote
Old 04-04-2007, 02:26 PM   #11
Chris27
Blazerless
Chris27's Avatar
EFI & overdrive is hard to beat, whatever way you go about it. If I did mine over again I'd go with a 6.0 litre/4L60E and a supercharger or turbo.
72' K5 Blazer 4x4 350TBI/700R4/NP205 3/4 ton diffs. Daily driver. SOLD
69' Beaumont 388/700R4 11.70@116
77' Bronco, Wife's mall cruiser/poser 4x4. Capable but too pretty to go offroad.
Chris27 is offline   Reply With Quote
Old 04-04-2007, 10:55 PM   #12
stingray72
stingray72's Avatar
Ok guys.. I think the way to go is updated engine.. Fuel injection and OD tranny. And boy would a Turbo be nice. Soon as my bike sells I'll really get down to business and start getting everything together.
Is the best place to find engine and tranny out of a wrecked car??
-Homer Simpson
