Old 04-03-2007, 08:59 PM   #1
jkade
jkade's Avatar
402 BBC for sale
The previous sale fell through so I am going to offer it one more time before I part it out. The motor does not include a intake, carb, or dist. After I pulled the motor I noticed the top of the spring where hitting the valve seals a little so I just got them back from the machine shop today and they are good to go. That is why the previous sale fell through. I have well over 2 grand in this motor and you wont buy or build on with all the goodies for any less. What I am asking is the low dollar amount. Those blue rollers are some I got off ebay used which where replaced with new 1.7 rollers. Please pm me with questions or for more pics.
$$$$1500.00
A list of some of the stuff I have put in or on the motor.
http://store.summitracing.com/partde...0&autoview=sku
http://store.summitracing.com/partde...1&autoview=sku
http://store.summitracing.com/partde...S&autoview=sku
http://store.summitracing.com/partde...2&autoview=sku
http://store.summitracing.com/partde...4&autoview=sku
http://store.summitracing.com/partde...5&autoview=sku
http://store.summitracing.com/partde...?part=EDL-7810
http://cgi.ebay.com/ebaymotors/ws/eB...9772612&rd=1,1
http://cgi.ebay.com/ebaymotors/ws/eB...m=330076040676
http://cgi.ebay.com/ebaymotors/ws/eB...m=330076787341
http://cgi.ebay.com/ebaymotors/ws/eB...m=260075823958
http://cgi.ebay.com/ebaymotors/ws/eB...m=220030460320
jkade is offline   Reply With Quote
Old 04-03-2007, 10:48 PM   #2
revn67
revn67's Avatar
Re: 402 BBC for sale
how much to ship to 01108? unless you aren't shipping to anywhere......then i apologize for asking
67 small windowed,shortbed,fleetside, sbc 327, th350,12 bolt :under the knife:
71 cab for sale in parts classifieds!
2004 black chevy 1500
"finish your beer, theres sober kids in india!"
revn67 is offline   Reply With Quote
Old 04-03-2007, 11:16 PM   #3
72armyswbtruck
72armyswbtruck's Avatar
BUMP, good buy for someone
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 04-03-2007, 11:27 PM   #4
Mt Man Chad
Mt Man Chad's Avatar
I might be interested!!!!!!
Bling Bling BIG BLOCK in my 67 SWB :O)
Can you drop it off at a conway freight depot.
I can get very cheap freight charges thru work!!!
Let me know
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 04-04-2007, 07:56 AM   #5
396muncie
396muncie's Avatar
None of the links seem to be working. Great deal!
70 Custom/10, 396, Muncie 4spd, SWB SOLD
72 Cheyenne K20, 350, Granny 4spd, LWB, daily driver
72 Cheyenne Super C20, 350, Turbo 400, LWB, parts truck for 4WD Cheyenne
396muncie is offline   Reply With Quote
Old 04-04-2007, 08:36 AM   #6
jkade
jkade's Avatar
Shipping would be between $300 and $400, this is from freightquote.com
Thanks, Kade
Old 04-04-2007, 08:40 AM   #7
jkade
jkade's Avatar
Let me know
The motor will be shipped from a business with a forklift, I have no idea where there is a conway terminal around here. You could figure 650 to 700 lbs on a 48"x40"x48" pallet. My zip is 35960.
Thanks, Kade
Old 04-04-2007, 09:14 AM   #8
jkade
jkade's Avatar
A little history on the motor. This motor came in my blazer which I have had a year and 5 months. The blazer was built in the early 90's and the motor was rebuilt back then, the motor only has around 3 to 5 k miles on it since it was rebuilt. I drove it 4 hours home and have drove it on several 400 plus mile trips before I tore into it. It never smoked when it had sit for a month without cranking or while driven. The motor always held great oil pressure and always ran cool. I pulled the pan a checked the bearings and they all looked good. The motor was very clean with no buildup anywhere. The cylinder walls looked good also. The heads are 206 heads, closed chamber, oval port, with 97 cc combustion chambers which should put the compression around 9.5:1. The heads have edelbrock sure seat valve springs installed and 1.7 roller rockers. The motor has a edl-7162 cam in it with new lifters, 3/8 pushrods and a edelbrock dual roller timing chain. It has ARP head bolts, patriot clipsetter headers that are 3/4 lenght and ceramic coated, new solenoid, new rear main, new pan gasket, chrome timing cover. The serp brackets are in good shape and have a new alternator with the plug that you can splice into your harness, new water pump, new water pump pulley, new crank pulley, new tensioner and pulley, the p/s pump is a 3 port so you can run hydroboost if you want to or just plug the extra port. The a/c compressor is shot so it will have to be replaced or buy the a/c delete pulley to go in its place. The motor will need some touch up on the paint where I have nocked it off pulling the motor. It also has a new balancer that was a major pain in the ass to get on there, we had to make out on installer to put it on since the parts stores where closed on sunday, it was a long grade 8 bolt and we used a bearing and some washers to get it on there. After we got it on and before we removed the bolt I had lost the balancer bolt, I cut the bolt off that we used to install the balancer and put a washer, loctite, and a nut to hold the balancer on the crank. To me it is the same as having the right bolt becasue it serves the same purpose and you cant see the nut on there with the pulley installed, this is not some half ass work so the balancer will fall off. I will also through in the radiator hoses since the upper was a major pain in the ass to find since a 67-72 truck or blazer never had a serpentine belt setup.
Let me know if you have anymore questions.
Thanks, Kade
Old 04-04-2007, 11:00 AM   #9
Mt Man Chad
I'm still game.............
Can you tell me the casting numbers on the block and casting date?
Can you send me the address the motor is at so I can find a close Depot??? Let me look up the local conway terminal near your house and I'll let you know how far away it is.
Chad
Old 04-04-2007, 11:14 AM   #10
jkade
jkade's Avatar
Chad
The address where the motor will be shipped from is
3950 Co Rd 63
Centre, AL 35960
This is a business with a forklift no dock.
I will get the casting #'s tonight.
Thanks, Kade
Old 04-04-2007, 08:40 PM   #11
jkade
jkade's Avatar
Name:  Copy (2) of kade 076.jpg
Name:  Copy (2) of kade 077.jpg
Name:  Copy of kade 079.jpg
Name:  Copy of kade 080.jpg
Old 04-04-2007, 09:04 PM   #12
jkade
jkade's Avatar
Name:  Copy of kade 081.jpg
Name:  Copy of kade 082.jpg
Name:  Copy of kade 083.jpg
Name:  Copy of kade 084.jpg
Old 04-04-2007, 09:08 PM   #13
jkade
jkade's Avatar
Chad
I ran off in a hurry this afternoon and forgot to get the casting numbers.
I will get them tomorrow.
Old 04-04-2007, 11:10 PM   #14
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
ttt for ya
IvelDesigns is offline   Reply With Quote
Old 04-05-2007, 11:20 AM   #15
Mt Man Chad
I'm going to pass on the 402!
I just picked up 2 SWB trucks and found a nice 396 BB locally.......
Thanks!
TTT for ya
Old 04-05-2007, 11:38 PM   #16
Cochise
Junior Member
Cochise's Avatar
Kade, I have a fellow near me that may be interested, I'll get back with you. Can you email a phone number so he can call you and axe some questions?
Cochise is offline   Reply With Quote
Old 04-06-2007, 08:33 AM   #17
jkade
jkade's Avatar
PM Sent
Old 04-06-2007, 08:44 AM   #18
Cochise
Junior Member
Cochise's Avatar
PM received.
Old 04-08-2007, 12:53 AM   #19
72 Cheyenne402
72 Cheyenne402's Avatar
Selling the shorty headers PM pls
1972 Cheyenne 402 LWB
2005 Silverado X-Cab 5.3L
2004 John Deere L120 20HP B&S
72 Cheyenne402 is offline   Reply With Quote
Old 04-08-2007, 10:04 AM   #20
killer71
killer71's Avatar
Is the motor still 4 sale?
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 04-08-2007, 09:56 PM   #21
jkade
jkade's Avatar
No parting, I have a lead on a 87 c10 that needs a motor and trans so I may end up with a beater that I can have a little fun with.
Old 04-08-2007, 09:56 PM   #22
jkade
jkade's Avatar
For one more week.
Old 04-08-2007, 10:12 PM   #23
454_72_4X4
454_72_4X4's Avatar
Just curious about the headers. I read through the description far enuigh to see they are Patriot headers. Where'd ya get 'em if ya don't mind. They look like something that might fi on my 72 4x4.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 04-09-2007, 01:55 PM   #24
jkade
jkade's Avatar
Summit was the place, they are for a chevelle.
Thanks, Kade
Old 04-09-2007, 08:24 PM   #25
jkade
jkade's Avatar
Well since no buyers I am going to take the motor over to my buddies shop and store it there till I can find me a beater to put it in. Thanks for all the replies and the interest. I have to get it out of my old man's way.
