Old 04-05-2007, 05:23 PM   #1
JkC824
Help Me
can someone please help me? I'll try to explain my best. I just bought a 1987 GMC 350, It has dual gas tanks and the PO told me that the right one needed a new pump so i put one in and it still didn't work. So i checked the switch. That was the problem. I started and both worked an then i tried to start it again and now my truck won't start at all. I have power at the switch and back to the plug where u connect the tanks in but as soon as i plug the tanks in i lose power at the switch and tanks and the truck will not start. PLEASE HELP ME! Could this be the oil pressure safty sensor switch?
JkC824 is offline   Reply With Quote
Old 04-05-2007, 08:59 PM   #2
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Lightbulb Re: Help Me
Theres a relay on the firewall remove & visually ck the connector & the relay too.
The relay has a 5 sec. timer in it so when you turn the key on you should hear the pump run and prime the sys.
Check both tanks for a proper ground.
Everything go's through the tank selector valve on the right frame rail so remove & visually check that connector as well.
If that all looks good then check the oil press. sw. that controles the fuel pump power.
There should be two oil press switch's one for the Insturment guage and the other one supplys pwr. to the fuel pumps once the eng. is running.
One is mounted at the rear of the intake manifold by the distributor and the other is next to the oil filter.
I cant remember witch one is what so remove the connector from one and see if the guage still works and go from there.
That should keep ya busy for a bit.
Good luck.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 04-05-2007, 09:13 PM   #3
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: Help Me
could be a fuse to. i like to check easy stuff
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 04-05-2007, 09:28 PM   #4
JkC824
Re: Help Me
I checked to see if i was getting power to the fuel selector switch and its there and i checked all fuses the thing that has me stumped is I have power until I plug in the tanks.. Im going to change that oil pressure switch. As far as that relay i don't hear the pump at all. Where is that relay located i can't find it on the schematics. I just want to thank you very much for trying to help me. its been pissing me off for over a week now. thanks again
