04-07-2007, 06:56 AM | #1 |
Post-66 frame question?
Isit feasable to use a newer frame under a pre-67 truck?I honestly have no idea.I ask because I have a 71/72 rolling frame that everything is rebuilt on,incl:p/s box brakes and f/e.It has an ECE 4/6 drop and is painted.Would it just be a matter of custom body mounts?Would it lay/fit under as well as a stock frame?Anyone ever do this.I know I can swap over to the right frame.But,wonder if this is possible,first.
04-08-2007, 01:10 AM | #2 |
60-66 Nut
Re: Post-66 frame question?
Putting a 60-66 body on a 71-72 frame wouldn't be that big of a job. They are real close in configuration, so there should be only minor issues to deal with. I've never done what you're asking, but I'm familiar enough with both frames. A couple of issues that come to mind are (1) the front frame horns are different (2) I think the core support mounts will have to be moved (3) if you use a 60-62 cab you will have to extend the front cab mounts on the frame.I have put a 62 body on a 76 frame and that was a PITA
04-08-2007, 09:01 AM | #3 |
How did the 60-62 sit on that frame?I mean,most of the body to frame swaps I`ve seen are on 4wds where height off of frame isn`t such a concern.I`d only want to do this if it was possible to "tuck" as original.Mine will be a custom and ride height is my focus.I`d want to know that when done the body to frame relation would be as "natural" with the original frame/body.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 04-08-2007 at 09:01 AM. |
04-09-2007, 12:43 AM | #4 |
60-66 Nut
When it was done, the 62 that I put on the 76 frame, looked about like a stock 1/2 ton 4x4. That's how it worked out due to the different configuration of the 73-87 frames. So basically the installation included a body lift. I didn't really like it, but that was what the customer wanted.
04-09-2007, 02:40 PM | #5 |
Yeah,unless I get everything all together I`ll just have to see how it would work out.Definately better to get frame and body together.
04-11-2007, 07:36 PM | #6 |
Im actually planning on puting a 63-66 body on my 72 3/4 4x4 rolling chassis, and from what I can tell they are going to be REAL close. I looked more at the body mounting locations of the cab and bed, but I cant see much other thatn minor frame horn differences that could be easily remedied. I just havn't seen too many of this body style in a 3/4 ton 4x4...
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
04-18-2007, 08:45 PM | #7 |
Not a bad nut after all..
How do the body mounts between a '60-'62 with the X member cross-member compare to the body mounts on a '63-'66?
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
04-29-2007, 05:43 PM | #8 |
60-66 Nut
The front cab mounts are farther apart (side to side) on the 60-62's than the 63-66's, but all you have to do is drill a new hole to swap them. The rear cab mounts are the same width. I don't remember for sure if the radiator support mounting is the same or not.....I think it is. IIRC some or all of the bed mounts are wider on the 60-62's but all of the bed cross sills I have seen have both hole sets in them. I do believe that the bed rear sill mounts are different between the 60-62's and 63-66's. It really isn't a very difficult swap IMHO.
