![]() Join Date: Jul 2000
Headlight fuses
On a 66 C-10, where are the headlight fuses?
And does anyone have a picture of the fuse box showing which circuit each fuse protects? Thanks, Mike
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
Re: Headlight fuses
There labeled on the box. or at least they should be.
Respect: 1. A feeling of appreciative, often deferential regard; esteem. 2. The state of being regarded with honor or esteem. 3. Willingness to show consideration or appreciation. When you fail to show consideration to others values you are showing disrespect. |
Re: Headlight fuses
Driver's side inside firewall. Tube fuses. 10a?
![]() Join Date: Sep 2006
Re: Headlight fuses
Dont think is there a headlight fuse.. Are yours not working? If not you may have a bad connection at the radiator support plug. It gets dirty in there and you may have to clean it. If that is not the problem put a jumper wire where the high beam switch is and see if they go on and if so your highbeam switch is no good and you can use one of those all the way up to the 80's untill they switched to the column high beam swtich..
Re: Headlight fuses
I don't think there is a fuse for the headlights.
Most headlight switches have a circuit breaker built into them. So, if you have power to the big red wire to the switch---the problem will be from the switch down to the dimmer or out to the headlights. If there is no power to the wire (which could be fed from the ignition switch or a buss in the fuse box), the problem will be between the battery / ignition switch / fusebox. Bryan
ElCamino 1959 454/5-spd ElCamino 1966 307/5-spd-----25+mpg ![]() Ranchero 1965 Factory 289 High Performance/4-spd (uncle bought new)(lil Blue Rocket) 98 Cheyenne EXT cab 350/5-spd Last edited by Bryan59EC; 04-07-2007 at 06:02 PM. |
