Old 04-08-2007, 01:39 AM   #1
WinDancer
The Original HotRod KnifeMaker
WinDancer's Avatar
Exhaust????
I spent two hours reading the results of my search on exhaust- my eyes are blurring
I am getting ready for the exhaust on my 69 GMC SWB 2wd. I have moved the tank under the back where the tire was.
I am running 3" all the way from the headers to the duals straight out the back.
Anyone have any tips or cautions based on experience with this kind of setup?
The truck sits real low.....
Thanks,
Dave
69 GMC SWB 2WD 454 Turbo 400
WinDancer is offline   Reply With Quote
Old 04-08-2007, 04:03 AM   #2
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: Exhaust????
with the low trucks alot of guys run the pipes inside the frame rails and through the crossmember to keep some ground clearence
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 04-08-2007, 08:31 AM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Exhaust????
Unless you just have one bad arse motor, 3" is a waste of funds, I worked
in a Muffler shop PT for 2.5 years so I have a lil knowledge on that subject
Anywhohow, it's going to be extremely tight in the back around / over axle
if it is slammed to the ground, just incase you rethink it here is a HP chart.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 04-08-2007, 09:11 AM   #4
Rokcrln
Rokcrln's Avatar
Re: Exhaust????
Just how low are we talking about? I sit on the low side with Slow Build and I built mine with the intention of 3" (Charged Lt1) but I am goint to keep it natural now and teh 2.5" is still going to be tuff to get all the way out. Is your frame C-notched, stepped or are you just as low as it will go with out these mods?
In the first pic you can see the curves added to the tranny cross member and the mouse holes added to the trailing arm cross member. Second shot shows the muffler placement to get up and over the trailing arms. Third shows bed floor mods to help make room for a few things. Fourth just because
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 04-08-2007, 02:10 PM   #5
WinDancer
WinDancer's Avatar
Re: Exhaust????
Thanks for the comments and info.
The truck is running a 400 horse 396.
The reason for the exhaust size is the sound, not just performance. Exiting the truck with the rear tank is where I suspect to have trouble if there is any
No mods to the frame but it is plenty low.
Thanks again!
Dave
Old 04-08-2007, 02:47 PM   #6
kbs71
71 rustless in texas
kbs71's Avatar
Re: Exhaust????
Here's pics of my exhaust. The first 3 are from the back looking up to the trans mount the 4th is over the axle and the last one is thru the crossmember that the trailing arms are on. Its 2.5" and I think they sound great. I'm running dynomax mufflers stright out the back. My gas tank is still in the cab, but I don't see a problem with a tank back there. I had a step bumper and that dropped the tail pipes considerably. After I removed it, I was supprised at how much more room I had to tuck those babies up. Which will happen during by rebuild of my truck.
"The secret to creativity is knowing how to hide your sources."
"No one really listens to anyone else, and if you try it for a while you'll see why"
71 C-10 LWB presently in a perpetual state of disassembly
'96 Toyota (my work car)
'04 Mustang Convertable (wife's car & other money pit)
Latest aquesition and why my trucks still in the garage covered with junk..
2010 Aqua Blue metallic 6 speed Manual LS3 2SS/RS Camaro (I want one of these in my truck
FAQ here
VENDORS here
SUPPORT THE BOARD here
My second favorite SITE
kbs71 is offline   Reply With Quote
Old 04-08-2007, 06:02 PM   #7
Senator350
Senator350's Avatar
Re: Exhaust????
Thru The Hood!
RN U OVR
Senator350 is offline   Reply With Quote
