Old 04-08-2007, 10:36 AM   #1
mholmes
Guage help
I have an '82 Scottsdale that I need help with. None of my guages work with the exception of the speedometer. The gas guage reads only 3/8 of a tank when full and the oil, temp, and charging guage do not move at all. They were like this when I bought the truck. I purchased the truck for the main purpose of pulling my boat 1.6 miles to the boat ramp and back. Plz let me know thoughts and ideas on what could be causing this. I am fairly mechanically inclined so if this is not a complicated issue I would like fix it myself.
mholmes is offline   Reply With Quote
Old 04-08-2007, 11:27 AM   #2
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: Guage help
Could be a ground or crossion. Id take out the gauges and clean everything up.
On my truck way back i had some issue like that but only fuel turns out it was loose. In the back the gauges dont screw in they push into clips and the clips can become loss and just need to be pushed back together to make it tight again.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 04-08-2007, 12:29 PM   #3
BeBeep
BeBeep's Avatar
Re: Guage help
I had the same problem as you do and I figured I was in for a bunch of troubleshooting to get all the gauges to work. Then....I got out my wire diagram and found which fuse was for the gauges and found it was blown. I replaced it and everything works as it is supposed to. Check your fuse first before you do anything else.
Good Luck,
Bob
BeBeep is offline   Reply With Quote
Old 04-08-2007, 07:06 PM   #4
mholmes
Re: Guage help
I may be missing it totally but from the wiring diagram I cannot see one fuse controlling al the guages.
Old 04-08-2007, 07:14 PM   #5
BeBeep
BeBeep's Avatar
Re: Guage help
Attached is a fusebox illustration for a 1980 truck someone emailed me. You can see that fuse "F" is for gauges, that is what I am referring to. Your box may be different since it is newer.
Old 04-08-2007, 07:34 PM   #6
mholmes
Re: Guage help
Got it, it's a 20A, I replaced it and still no go, however, my oil pressure guage now at least moves.
Old 04-08-2007, 08:54 PM   #7
BeBeep
BeBeep's Avatar
Re: Guage help
I was keeping my fingers crossed for you. Too bad that did not take care of all of them. Best of luck with your troubleshooting, I hope it is a fairly easy fix.
Old 04-08-2007, 09:27 PM   #8
knightlife
Dark Heart Motorsports
knightlife's Avatar
Re: Guage help
start checking wires! the fun has only began young sky-mholmes....trace all the wires and leads thru the firewall into the engine bay, look for wires that are rubbing all around the back of your engine above the transmission. then check all of your sending units (the speedometer cables arent made like they used to be, hence why I recently went digital...couldnt keep a cable...kept snapping lolz). definately check the sending unit from your fuel tank to your gauge...seems thats a pretty common prob these days.... the temp gauge, is located on the drivers side of the engine, underneath the heads, between the 2 and 4 cylinders its one wire, that usually comes disconnected during driving. should be a green wire? that connects to that lil bitty nob on the block.
holla if those dont give you the right findings, we chere fer ye...
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
