Old 04-09-2007, 10:36 AM   #26
54Nlow
54Nlow's Avatar
Re: Lowering a 1957 GMC 3/4 ton
you will probably need to c-notch the frame above the axle, and also you need to address steering issues. you may create a lot of bump steer, and have to modify the steering linkage to correct the change in geometry.
Hi 1-ton of fun
thank you for the information of this.
can i put the same Shackle kit? Ok maybe the shock absorber i must exchange.. have you pics for me ?
Thx F.S
54NLOW
54Nlow is offline   Reply With Quote
Old 04-09-2007, 11:43 AM   #27
1-ton of fun
polishing a turd
1-ton of fun's Avatar
you will need shorter shocks. you could use the stock shackles (i think). most of the work will be in correcting steering geometry.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 04-09-2007, 11:51 AM   #28
Riggs'57
In doing the spring flip on the front suspension, you will somehow have to address the fact that the axle has a mounting surface ony on the top, where the springs are in the stock location. The bottom is only skinny I beam. Maybe some good welding will help. If anyone has done this, I'd like to know how, because nobody makes a 3/4 ton drop axle. bummer. Should I just find a 1/2 ton before I spend any money in the 3/4 ton? I just got it and have spent (traded) a 77 chevy and 300 dollars on it. someone out there will trade me for a first series 1/2 ton!
Riggs'57 is offline   Reply With Quote
Old 04-09-2007, 11:54 AM   #29
1-ton of fun
polishing a turd
you could just use 1/2 ton axles under your truck...then you can bolt on discs too.
Old 04-09-2007, 12:41 PM   #30
1-ton of fun
polishing a turd
there is some info in the second half of this thread that i just found:
http://www.stovebolt.com/bboard/cgi-...=001233#000011
