soon to be bagged64sub
2 piece Drive Shaft????
As you can see in my other thread I just Zd my frame 3". My problem is that my driveshaft was about .25" from hitting my crossmember where my upper bars mount before I Zd it. SO now that it is Zd, the front of the driveshaft is moved up 3" therfore it is definately gonna hit now. Im thinking about running a 2 piece and putting the carrier bearing on that crossmember. Would this work? Any pros and cons would help. Thanks alot.
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON ![]() 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
Re: 2 piece Drive Shaft????
Don't think it's gonna work man. I think you have to cut the cab. I have a two piece and no Z, and my drive shaft is almost hitting the cab, and I am an inch from laying out.
The cab is not the problem. I cut the cab before the Z. Its the crossmember that my upper bars go to that I dont wanna cut out. Ill post a pic of the crossmember Im talking about.
This is what Im worried about. I guess Im just trying to find an easy way out.
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON ![]() 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck Last edited by bagged69c10; 04-10-2007 at 10:41 AM. |
Commander Taco Bello
with that setup, i would think a 2 piece driveshaft would work just fine. mount the carrier bracket to your x member that you made. Depending on where your x member is compared to factory, you'll probably have to get a drive shaft made for your truck.
oh ok. I agree with Ivel. Fabricate a bracket for the carrier bearing on your crossmember and get the shaft as high as you can. This will minimize your working angles. You should be doing all this at ride height so you can make sure all your working angles at the u-joints are within limits.
Would anyone happen to know the working angles? My truck had a 1 piece so Im kinda clueless on the 2 piece.
at ride height, all angles should be 2-3 degrees. do a quick search in these forums and you'll see a few threads on this topic.
this is a must read so you know why your doing what your doing!!!
http://www.airridetalk.com/articles/...-joint-enigma/ |
Very helpful link. I forgot about that forum! There are way to many forums to keep track of.
