Old 04-11-2007, 09:45 PM   #1
stefan
New Member
72 with front drop problems
first of all i lowered it 5 and a half inches and my brakes lines are like banjo strings it wont even turn,is there any other year hose that will work or do i have to get a pair built,and second i want to run the exhaust through the frame rails and im clear on both sides all the way back except for the shifter linkage is in my way well i saw a 68 in dallas where it was still on the column but the exhaust was in the frame but no one at the car lot knew how he did it and they wouldnt air it up to see,man any help will be greatly appreciated.
stefan is offline   Reply With Quote
Old 04-12-2007, 05:40 AM   #2
royo
royo's Avatar
Re: 72 with front drop problems
Hello get you some new brake lines off a 4x4 they are longer but we need pics
nickle and dime
royo is offline   Reply With Quote
Old 04-12-2007, 01:03 PM   #3
pharcyde05
pharcyde05's Avatar
i had some made there not that much more then buying new ones and why risk putting some used ones off another old truck
if you have them made you can get them however long you want them
put up some pics so we can see where you wnat to put the exauset
pharcyde05 is offline   Reply With Quote
Old 04-12-2007, 05:39 PM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
Lokar makes column shifter linkage that will get it out of your way. $$ though. I used it on my Blazer- quality stuff...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-12-2007, 07:02 PM   #5
bedsled71
bedsled71's Avatar
i just cut the metal bracket that holds the line on the crossmember where it turns into flex hose
bedsled71 is offline   Reply With Quote
