04-14-2007, 04:52 PM | #1 |
Attaching firewall insulation
I'M installing new firewall insulation pad and the plastic push pins seem to big. They do not want to go in. Is there a special tool to drive them in? Whats the trick?
04-14-2007, 05:21 PM | #2 |
GEARHEAD
Re: Attaching firewall insulation
I have not done this on our trucks but I have done it. make sure the inner dia. of the pin is not bigger than the hole. Then I use the top of a hammer (where the handle come out the top) not the head unless you have a tight spot
04-14-2007, 06:04 PM | #3 | |||
Union Electrician
x2 on the hammer, although I would use something closer to the actual diameter(maybe 3/8" socket extention) of the plug and tap on it using the hammer to drive the plug in.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
04-14-2007, 08:52 PM | #4 |
Also a little liquid soap or radiator hose grease works wonders too.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
04-15-2007, 08:36 AM | #5 |
thanks guys will give it another try today
04-15-2007, 06:35 PM | #6 |
Active Member
I'm pretty sure that I saw an installation tool for the firewall insulation holders. I think it was in a Truck Shop catalog. It was a simple step shaft. Wasn't very expensive if I recall.
