Old 11-28-2002, 08:00 PM   #1
70 RatRocket
Another A/C question
I have 70 1/2 ton 4x4 with factory air. Everything is in the dash but some of the stuff is missing under the hood. Found a 69 3/4 ton 2 wheel drive with factory air. Will all the 69 A/C stuff interchange with the 70? Will any of the later trucks (73-87) A/C stuff work in the 70? Both trucks are factory automatics. Thanks!
70 RatRocket is offline   Reply With Quote
Old 11-28-2002, 10:40 PM   #2
Piston
Piston's Avatar
As long as the engine configuration is the same on both, you should have no trouble( other than the fan shroud).
The 73+ is different, they used a long waterpump configuration which makes the brackets and pulleys different. You'll be able to use the compressor as long as its the original A-6 design. 73+ also used a fixed orfice tube instead of the old POA valve.
Piston is offline   Reply With Quote
Old 11-28-2002, 11:11 PM   #3
70 RatRocket
[QUOTE]Originally posted by Piston
[B]As long as the engine configuration is the same on both, you should have no trouble( other than the fan shroud).
Is the fan shroud differnt ? Mine is missing now. Hope I can use the one off the 69. Also, does the radiator need to be a 4 core or will a 3 core work alright?
1970 Chevy SWB 4x4
1970 Chevelle SS 454
1972 Chevelle Heavy Chevy
1950 Ford Convertible
2001 Chevy HD2500 4x4
Old 11-29-2002, 06:45 AM   #4
JimKshortstep4x4
Talking
A good 3 core radiator will work and all of the 69 parts should work, assuming the engines are similiar, (both big block or both small block).
You will want a shroud, especially with AC.
Jim
Old 12-01-2002, 09:01 PM   #5
Piston
Piston's Avatar
4x4 shroud is different (longer) than a 2wd. The engine is set back and requires a deeper shroud.
Old 12-01-2002, 09:43 PM   #6
BOSS
Just here to help
BOSS's Avatar
I have a ? also about air.I know anything is possible...lol.but has anyone used everything from a 73 up air on these trucks?I hate haveing to buy anything that i have laying around already,and it's nice to be different.......James
Support our site
Norwood Survivor
BOSS is offline   Reply With Quote
Old 12-01-2002, 11:01 PM   #7
70 RatRocket
I got the 69 truck yesterday. All the A/C is still there. It even works! Only problem is the truck has the 396 still in it and my 70 is a 350. I think I will have to find some small block compresser brackets. Thanks for the help.
1970 Chevy SWB 4x4
Old 12-01-2002, 11:06 PM   #8
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
I could use a fan shroud for an A/C BB truck
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 12-02-2002, 08:27 AM   #9
70 RatRocket
Chevy2racr, I might be going to drop a small block in that truck to sell it after I get the AC off. My son wants the BB for his 68 chevelle. Your not all that far away. Maybe we can get together.
1970 Chevy SWB 4x4
