Old 04-16-2007, 08:13 AM   #1
Nikkortim
In need of 1985 engine photos
Hey Guys (and gals),
I hope you can help me out. I had a friend rebuild the engine in my '85 Silverado. He didn't think I needed a lot of the emission stuff, and vacuum lines, and took many of those off, and plugged some lines on the Q-Jet.
Without reference I don’t exactly to start. I have the chart under the hood, but that only helps part way.
If any of you could supply me with photos and some indications of what is what in reference to the emission chart I would very grateful.
I tossed around the idea of switching the carb, but I think finding and reinstalling the lines, tees, and valves will be cheaper.
Thanks,
Nikkortim is offline   Reply With Quote
Old 04-16-2007, 02:00 PM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: In need of 1985 engine photos
Your carb should work fine with everything disconnected, if that is your only worry. Just make sure to cap off all vacuum fittings that are not used.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 04-16-2007, 02:30 PM   #3
benoit454
Chris
benoit454's Avatar
I agree our 86 had it all removed and blocked off, you don't need it unless you have to pass emissions inspection.
I know our 84 has everything still on it, and I considered taking it all off, but ir runs fine now so I doubt I will.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 04-17-2007, 04:19 AM   #4
AceX
>130dB Moderator
AceX's Avatar
I want to remove everything so badly... It would clean up the engine bay really well...
Also, get yourself a shop manual. They help, trust me...
AceX is offline   Reply With Quote
Old 04-17-2007, 07:24 AM   #5
Nikkortim
OK, that helps a lot thanks.
Two other things, the blue wire from the choke goes back to a round housing that has a female AC style connector in side. What activates the electronic choke?
On the top front corner of the carb there are two wires coming out at a 90 degree angle. One is pluged in the other is hanging (I think it is brown). Any clue?
Old 04-17-2007, 07:59 AM   #6
greg0380
these pics are of the emissions stickers from my 85 donor. I have some pics of the engine if you still need help. Let me know and I can send them.
1985 GMC Sierra 1500, 1/2 ton, 2WD, LWB, TBI 305
5 speed, 3.42 rear
2007 GMC Sierra 1500, xtended cab, 4X4, flexfuel 5.3L
1999 BMW 528i
greg0380 is offline   Reply With Quote
Old 04-17-2007, 10:52 AM   #7
Slonaker
Slonaker's Avatar
You lost me on the "AC style connector" part... The choke is electric, and activated by an oil pressure switch. On an '85, the switch is mounted on a tee behind the distributor. If not there, I think it will be on the side of the block near the oil filter.
That is the dual stage accellerator pump. These are found only on '85-'86 trucks. One wire should go to a temp switch on top of the thermostat housing. I think the other end plugs into the wiring harness that goes above the passenger side valve cover, but I'm not sure. It has been a while since I had that on my truck.
Slonaker
Stock '01 Silverado
Old 04-17-2007, 12:01 PM   #8
Nikkortim
Aahhhh that explains a lot. The oil and water senders have been replace by Dakota Digital senders in preperation for a dash install.
Old 04-17-2007, 12:45 PM   #9
wedgemon
wedgemon's Avatar
Cool Re: In need of 1985 engine photos
Here's all you really need...
(I plagiarized this drawing and edited all I didn't need.)
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 04-17-2007, 10:46 PM   #10
Pyrotechnic
Pyrotechnic's Avatar
+1 weddgemon
The stock diagram looks like a nightmare. No way I would reconnect all that.
Pyrotechnic is offline   Reply With Quote
Old 04-25-2007, 08:07 AM   #11
Nikkortim
Thanks for your help guys, espcially Wedgemon. That I can do, and it should take care of a couple of issues.
BTW my friend failed to hook up power to my choke so that "was" a minor problem. As it sits now it runs ok but the Q-Jet needs a bit of tweaking.
Thanks again.
Old 04-26-2007, 01:13 PM   #12
bigbadbowtie
Slonaker
Question..... The temp switch you are refering to..... when closed is that switch then tide to ground. Im assuming when the engine gets warm that switch closes causing a short to ground??? Am i correct??
Ray in bama
78 Z28 Camaro,355 roller,10.78@127
86 C10 dog tired 305
bigbadbowtie is offline   Reply With Quote
Old 04-26-2007, 02:02 PM   #13
Slonaker
Slonaker's Avatar
It has just one wire going to it, so I assume it just grounds it to the block. I don't know the details. I mostly just wanted it gone.
Slonaker
Stock '01 Silverado
