Old 04-20-2007, 07:05 PM   #1
st1x10
st1x10's Avatar
4.5/6?
I am looking into lowering the truck. I want the 2.5 drop spindles from ECE and probably some 2" springs. Out back 4" springs should be in monday and then 2" blocks. Also getting super track bar and disc brake parts. Should I have any problems with 4.5" up front? What else should I look into?
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 04-20-2007, 07:29 PM   #2
72chevy327
Re: 4.5/6?
y the 2" blocks the 6" springs are the same price as the 4".
72chevy327 is offline   Reply With Quote
Old 04-20-2007, 07:35 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: 4.5/6?
4.5 is fine in the front. It will ride stock. Raise the sway bar if you have one though.
I run 5.5 in the front of mine and drive it everywhere.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-20-2007, 07:44 PM   #4
SCOTI
SCOTI's Avatar
Re: 4.5/6?
I agree 100%.... especially the raising of the sway bar after installing urethane bushings (they make a difference). You could also just try cutting 1 coil if you don't already have the front drop springs.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 04-20-2007, 08:20 PM   #5
st1x10
st1x10's Avatar
Re: 4.5/6?
Well the front springs are old and sagging so I would rather get a new spring up front. The 4" inch spring is what I got off a board member and the 2" blocks are for if I decide to bag it in the future. I am attempting to make a setup that is ready for bags if I decide to do them, right now it isn't an option.
Edit:
Also looking for some rally wheels off a 73 - 80 something. What is the going rate for those (15x8)?
2002 Chevy S10 V6
Old 04-20-2007, 11:39 PM   #6
SCOTI
SCOTI's Avatar
Re: 4.5/6?
Edit:
New springs would be the better option then.
As for 15x8 ralleys, $20ea bare up to $50ea loaded (trim rings & centers). The contributing factor on cost is the demand.... someone who needs them out of their way will let them go cheaper than someone looking to make a profit.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
