Old 04-21-2007, 09:21 AM   #1
"67"StepSide
Junior Member
"67"StepSide's Avatar
Lightbulb Big block motor mounts??
I have a question about big block motor mounts for my 67. I see that a lot of people on here say that if they're selling big block motor mounts, they are for 67 to 71, and that 72 is all by itself. Can somebody please explain to me why this is, because I'm putting in a front suspension from a 72 3/4 ton under my 67 frame. What motor mounts for a big block do I use? This truck is two wheel drive. Because I'm looking for a set of mounts for a big block, I just don't know which ones I need. Thanks, John
"67"StepSide is offline   Reply With Quote
Old 04-21-2007, 11:33 AM   #2
kwmech
Re: Big block motor mounts??
You can actually use either set-up, but if you are using the 72 x-member it will be easier to use the 72 b'cuz the lower hole in the x-member will already be drilled. Does that make sense?
Old 04-21-2007, 11:52 AM   #3
mikeoj
http://67-72chevytrucks.com/vboard/s...k+motor+mounts
69 Lwb C-10 402/700R4
70 Lwb C-10 250/3pd
Wisc.
mikeoj is offline   Reply With Quote
Old 04-21-2007, 12:22 PM   #4
"67"StepSide
Junior Member
mike thanks so much that cleared it all up for me!!!!!!!!!!!!!!!!!
Old 04-22-2007, 10:24 AM   #5
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I've got all different answers to ths question including that the 68-71 will work you just need to drill a hole in the frame. I was recently told by a
vendor on this site when inquiring about purchasing 68-71 fior my 72 bb I would not have to drill holes.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 04-22-2007, 01:36 PM   #6
mal68ibu
Parts Hunter
mal68ibu's Avatar
I'm just readin this thread and now you have me scratching my head. I just pulled a set of small block mounts from a 72 to install on my 67. Am I in for a headache? BTW does anyone know the difference between the V6 mounts and the BB mounts? I dont have the faintest idea what is in my truck, but my 350 is sitting too high right now.
1968 Chevelle 300 DLX (350 4 speed)
1984 GMC 2500 6.2, 700r4 work truck
1967 GMC Custom (was 6.5 Turbo Diesel powered)
My ebay Store: http://stores.ebay.com/The-Musclecar...3aFQ3aSTQQtZkm
My website:http://themusclecarshop.net/
1967 GMC 6.5 TD conversion build:http://67-72chevytrucks.com/vboard/s...d.php?t=290922
mal68ibu is offline   Reply With Quote
Old 04-22-2007, 04:14 PM   #7
redhead69
fugedaboutit
redhead69's Avatar
I'm pretty sure you have to notch the frame on a 67 to get the bb stands to work(frames wider on 67s in the front), and then I am assuming you would have to drill holes to bolt them down. I've heard of people puting a bigblock in there truck on small block towers, but requires the use of headers.
Currently truckless
redhead69 is offline   Reply With Quote
Old 04-22-2007, 04:40 PM   #8
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Anyone know if this is true? Got bb going in 72 and have sb towers and headers. Will it work??????
Old 04-22-2007, 09:23 PM   #9
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
ttt
