Tail light wiring
I took the tail lights off last fall to put the rust proofing wands in and had read on the site where someone said he painted the metal part the bulbs sit in white and got brighter tail lights.
I want to sandblast epoxy primer and paint them white. The lower larger metal section with one bulb was easy to disconnect the wire off the back push twist and it comes off. The to psmaller piecs that is approx 2 x 2 with one bulb in it is different and cant figure out how that wire comes off or sort of looks like it doesnt. Prefet not to cut it and put a connector on dont want condensation in there. Am I missing the point does the wire come free of that connector?? If so how. Thanks, Warren |
Re: Tail light wiring
there is a plug about 6"from the socket
common sense isn't so common anymore |
like wibilly said, and it can be a ***** to unplug.......pull on the plug, not the wire.
1997 GMC Sierra Ext 1965 Mustang |
Thanks,
Will go down under the truck as it is now there was not length of wire that I coulld pull through, the bottom yes it came well out from the truck and was easy to figure out. I was only able to pull it out from the truck maybe 2". Makes sense will crawl under today, Thanks, Warren |
