Old 04-22-2007, 09:09 PM   #1
jor
Heater Control Knobs
87 Suburban
How do you get these &^%^%$% lever knobs off so I can get this plastic cover off and polish it up? Thanks.
jor
jor is offline   Reply With Quote
Old 04-23-2007, 03:06 AM   #2
kevinr1970
Re: Heater Control Knobs
If I remember right you just pull. Real hard!
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 04-23-2007, 09:34 AM   #3
jor
I kept thinking there should be an allen screw or something but it sure looks like you're right. I'll grab on, close my eyes and give it a try. Thanks.
jor
Old 04-23-2007, 04:20 PM   #4
Chevyboy1962
C10 now is a GMC
Chevyboy1962's Avatar
Jor,
They're held on by a clip that is inserted into the knob. Just pull out on them, and the should come off. They will be on there pretty firmly.
David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod
*1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser
*1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project
Chevyboy1962 is offline   Reply With Quote
Old 04-23-2007, 06:18 PM   #5
wedgemon
wedgemon's Avatar
Find something to hook behind the knob. The spring steel clips on the levers are sharp and will remove bare finger flesh quite efficiently!!
FYI!!
- Dave
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 04-24-2007, 10:56 AM   #6
jor
Great advice. Thanks. I ended up using a pair of brake pliers to hook onto the back of the knobs. I gave them a pop and off they came. Just had to locate them as they went flying into the back of the Burban.
jor
