Old 04-25-2007, 04:31 PM   #1
nbr1chinchilla
coating rearend and leafs
What have you guys used to coat your leafs and rearends? I'm gonna get them blasted, but not necessarily sure if they need to be powdercoated. What are some different things that have been done? I just want it to look good underneath.
nbr1chinchilla is offline   Reply With Quote
Old 04-25-2007, 05:11 PM   #2
Evans
Evans's Avatar
Re: coating rearend and leafs
Rustoleum Semi-gloss black or Chassis Black from local auto paint shop
Evans is offline   Reply With Quote
Old 04-25-2007, 11:04 PM   #3
matthufham
i wirewheeled it with my drill, put rust preventative primer and gloss black from rustoleum on. i did my whole frame like that and much of the suspension.
matthufham is offline   Reply With Quote
Old 04-26-2007, 07:23 AM   #4
That paint that TSC sells is real good,too.
Old 04-26-2007, 09:06 AM   #5
nbr1chinchilla
Thanksfor the ideas guys. I will just wire wheel is to save me a little bit of dough getting t blasted.
Old 04-26-2007, 10:08 AM   #6
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 04-26-2007, 10:46 AM   #7
OLDIRON69
If your main concern is rust, I would try POR 15, but there are many other products that do the same thing for less money. Here in Texas, a good cleaning and a good coat of paint goes a long way, then again we don't have the salt/snow all winter like some of you guys. I use an industrial rust incapsulator (sp??) from Zep. It comes in gallon jugs and spray, it works great on anything I have that is rusted.
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 04-26-2007, 11:04 AM   #8
BigTruckDriver
BigTruckDriver's Avatar
I would apply the por 15 its bad stuff. If you spray it you will get a flat or semi-gloss look depended on how much pressure you use. If you brush it on it will come out glossy and looks very good for brushing it on. You will not even be able to tell it was brushed. Just hit everything with a wire brush and clean all grease of and this stuff will stick like powder coating .Hitting it with a hammer will not chip it. A pint cost about 40 bucks and goes a long way .IMO its very cheap and durable . I have not tried any of the other products though I got hooked on this stuff.
BigTruckDriver is offline   Reply With Quote
Old 04-26-2007, 11:26 AM   #9
OLDIRON69
I have heard many good things about the POR 15, My buddy did the hammer test on his mopar and he swears by it. He coated the whole underside of his car, he said you want to clean the piss out of it, let it flash rust then coat it.
05 2500HD 6.0 excab
