04-27-2007, 09:41 PM | #1 |
Wrong freaklin starter Solenoid!
My 71 wiring on the Solenoid has R & S. Yellow & Purple wires in the harness. However the Solenoid installed on my starter only has one terminal. Will I have to get the older Solenoid with the two terminals or can I hook both of the wires on the one terminal???? Anyone know? Sure hate to remove that starter again. Whats my options?
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
04-27-2007, 09:48 PM | #2 |
Designated A-hole!
Re: Wrong freaklin starter Solenoid!
You're best bet is to convert to HEI, then you won't need the other terminal. The points dizzy that came stock uses ~9v (supply wire is a resistor wire)while running, for starting purposes the yellow wire supplies 12v to the coil for a hotter spark. HEI uses 12v all the time so you don't need the extra terminal. Basically the news is that you need the 2 terminal solenoid if you have the points dizzy.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
04-27-2007, 09:53 PM | #3 |
I have the HEI installed except the wiring which is what I was doing wiring the starter POS lead. So I can forget the yellow wire & run a unfused to the HEI?
04-27-2007, 09:58 PM | #4 |
Designated A-hole!
Yeah, if you have HEI you can eliminate the yellow wire altogether. I ran a 12ga. wire from the ign unfused terminal in my fusebox to the distributor and that's it, although most folks will recommend putting an inline fuse in it somewhere.
04-27-2007, 09:59 PM | #5 |
Designated A-hole!
Click on the Index link in my sig for the FAQ writeups on the HEI wiring.
04-27-2007, 10:13 PM | #6 |
Thanks..yeah I went & found Longhorn Man's FAQ & re-read it. 12 ga with a fuse..Thanks again!
04-27-2007, 11:53 PM | #7 |
Designated A-hole!
No problem.
