05-01-2007, 10:40 PM | #1 |
hillbilly
62 to a 66
im switching a 62 cab to a 66 frame any ideals or trouble spots i will need to focus on and also i have the 283 in it and i want to switch it to a five speed does any body know if a s-10 2.8 transmission will work it has the removeable bellhousing and i have a bellhousing for it i belive im switching from a 350 turbo. any help would be great and you guys seem awesome. well thanks in advance. oh yea firts post. thanks,
john miller |
05-02-2007, 06:52 PM | #2 |
Re: 62 to a 66
Front cab mounts are different. Do you have the '62 frame? If so, remove the front cab mounts from the '62 frame and weld them on the '66 frame. That's what I did when I put my '62 cab on a '63 frame.
05-03-2007, 09:27 AM | #3 |
hillbilly
Re: 62 to a 66
yea the truck is still setting on the 62 frame is there any thing else different? i was going to switch the front mounts over. i was going to switch the arms and spindles over so i can go to disk brakes but i dont know what years i can get them from.
05-03-2007, 01:23 PM | #4 |
Re: 62 to a 66
I swapped in a '73-'87 front crossmember on mine. I know '71-'72 will also work.
05-03-2007, 03:37 PM | #5 |
hillbilly
Re: 62 to a 66
this thread is sticky and i dont want switch crossmenbers i wonder if the a arms are the same
http://67-72chevytrucks.com/vboard/s...d.php?t=171667 |
05-03-2007, 06:42 PM | #6 |
Re: 62 to a 66
Yeah, you can just swap the arms on the '66 frame.
05-03-2007, 07:33 PM | #7 |
1962 C-10
Re: 62 to a 66
I think you the spindles from a 71-72 will bolt up to 63-66 A-arms. Correct me if I'm wrong, just what I've heard. My 62 is has a 73-87 front crossmember on the original frame. It's been on there since the late 70's...works great..Good luck with your project!!
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
05-03-2007, 08:42 PM | #8 |
hillbilly
Re: 62 to a 66
i guess i just need a 71- 72 2wd 1/2 ton with disc brakes that should be easy to find. how bout the 5 spd?
05-06-2007, 09:25 PM | #9 |
hillbilly
Re: 62 to a 66
no luck yet on the brakes i might have found a 5 spd. would a mig welder do the welding to the frame ? if so where should i get one cheap?
-1962 C-10 |
05-06-2007, 10:07 PM | #10 |
BODY SHOP SUPPLIES INC.
Re: 62 to a 66
was the 62 not torsion bar front???
05-07-2007, 12:15 AM | #11 |
Re: 62 to a 66
yep its torsion bar get ahold of a plasma ccutter and cut the trann member out and order in one from CPP and bolt the tranny up that way and you can have front discks and coil springs
http://i11.photobucket.com/albums/a1.../DSCN20132.jpg |
05-07-2007, 01:52 AM | #12 |
New Member
Re: 62 to a 66
If you still use the your 62 or 66 control arms and want to use the 71 to 72 spindle remember to change the ball joints on the control arms since that would be the only difference.
Anthony 63 chevy stepside SWB 57 chevy 2dr hrdtop belair |
05-07-2007, 01:12 PM | #13 | |
hillbilly
Re: 62 to a 66
so if i get 71-72 ball joints and spindles it will go all together with disk brakes? what about 73-87 a-arms.
-1962 C-10 |
05-07-2007, 04:15 PM | #14 |
1962 C-10
Re: 62 to a 66
About the 5 speed. I read somewhere that the one that will work is a T5 that was off a 4.3 vehicle. Like an S-10 or an Astro van.
05-07-2007, 06:30 PM | #15 |
hillbilly
Re: 62 to a 66
i think i know where one is but just waiting to see if i can get it. and i looked at my frame today the rear mounts are differnent too? right?
-1962 C-10 |
