Old 05-08-2002, 05:54 PM   #1
slam33
slam33's Avatar
Post New U-joint for you 4x4 guys
Just looked at CTM U-joints, bearing less, blow proof. Not cheap, $150 a pop. They have em for the front axle Dana 60/44/30 right now but there working on rear shafts and 2wd also.
71 basic C-10 350. The only option is the rust.No nothing on it, but thats all about to change. <A HREF="http://www.geocities.com/stevemau/slam33page.html?1004806705410
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
</A>
slam33 is offline   Reply With Quote
Old 05-08-2002, 07:04 PM   #2
LeRoy
Registered truck nut
LeRoy's Avatar
Smile
Pretty cool but another though is that I want my U-joint to be the weakest link. There relatively cheap and easy to replace. Those look like, I'd twist the driveline or axle shaft before they broke. lol
MOUNT VERNON, WASH. STATE
GOT MY BASES COVERED
-Big and bad 70 CST Blazer
-71 K5 Blazer, 350, 4spd, 2" lift, 35" BFG mudders, Camo,
-Work in progress 72 SWB
-72 Cheyenne, lwb, 1/2 ton, 4x4, V8, 4spd.
-71, 3/4 ton, 402/400, Custom Camper
-69, 2wd, ST6, auto, ghetto lowered, 3/4 ton, LWB, "BOMBER"
-69 Chev. short narrow 4x4
-69 Chev., lwb, utility trailer, 35" tires,
Add or Delete Daily
Need a part? Just PM me
LeRoy is offline   Reply With Quote
Old 05-08-2002, 10:14 PM   #3
ddsmith
Glowing since 1978
ddsmith's Avatar
Post
I second the weakest link idea. The vette has a 454 and six u-joints two on the driveshaft and four on the half shafts. I'd rather replace them than rebuild the rearend.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
79 Chevy 4X4 (Tom's old truck)
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 05-09-2002, 12:36 AM   #4
Scrub
Collector of rusty Items
Scrub's Avatar
Post
Spinning rubber is my idea of a weak point. Do they make that joint in a 1410?
Got a link to these joints?
Scrub
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
Scrub is offline   Reply With Quote
